Ambient temps for assembly
What is the coldest tempeture...you could get away with while assembling the top end of a 3.0...thats installing Case studs to cam tower's and final torque...how does the locktite 574 react to the colder temp's .....Thanks Frank
Old 12-05-2003, 12:22 PM
Super Moderator
cstreit's Avatar
I did it in a 55 degree propane heated drafty garage... No problems... No leaking.. (knock wood)
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-05-2003, 02:34 PM
Now in 993 land ...
aigel's Avatar
I think any cool temperature at which you are still comfortable working at will be just fine. The Loctite will cure eventually, if it needs to be it will cure once you run the engine.
G
81 SC (sold)
Old 12-05-2003, 11:32 PM
