Ambient temps for assembly
What is the coldest tempeture...you could get away with while assembling the top end of a 3.0...thats installing Case studs to cam tower's and final torque...how does the locktite 574 react to the colder temp's .....Thanks Frank
Super Moderator
I did it in a 55 degree propane heated drafty garage... No problems... No leaking.. (knock wood)
Now in 993 land ...
I think any cool temperature at which you are still comfortable working at will be just fine. The Loctite will cure eventually, if it needs to be it will cure once you run the engine.
![]() G |
