is it by the #4 or #6 cylinder?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Eagle Driver:
FWIW, 7R's do crack behind the #3 cylinder in the rear case wall after sustained 7500 RPM usage. How long its lasts depends on how much time is spent in those RPM ranges and how many races you do per year. I would not hesitate to keep a good spare 7R case around.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Sorry about the late reply, I was out of town for a few days. The crack was on #4. There is only one head stud that doesn't have a case through bolt next to it. That's the one where the case cracked. Thanks for the advise Steve. I keep the revs to 7300 max and normally shift at 7k.
-Andy 72 RS replica E stock racer
72 Carrera RS replica, Spec 911 racer |
I don't know about a 4R case, but when I compare my 7R case with a 3R case there are a lot of reinforcements done. It seems to me that more is better in this regard.
3R ![]() 7R
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
