nreed's Avatar
bead blasting heads
Is it possible, if I'm careful, to bead blast (plastic) the heads without damaging the area that mates to the cylinder? I have never used a bead blaster before and am not sure what to expect. Is there a way to protect the mating area if this is an issue?
Also, I don't have a valve spring compressor. Is there a work around tool or should I just order one?
Thanks,
Norm
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 12-18-2003, 01:08 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Are you rebuilding your top end or just having them cleaned up to look better? A machine shop can disassemble your heads and have them cleaned for a small fee.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-18-2003, 01:21 PM
Friend of Warren
Just use masking tape. Masking tape has enough "give" that it will stay in place thru the bead blasting.
Kurt V
Old 12-18-2003, 01:48 PM
