thor's Avatar
head conversion
hello ,
is it possible to convert a 69 E head to a S head (larger valves) or not ?
thanks
Old 12-18-2003, 01:02 AM
jluetjen's Avatar
It's most likely cheaper and easier to just convert to some 2.2 heads or even 2.2S heads.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-18-2003, 04:38 AM
thor's Avatar
really ??? it s easy to put 2.2 head on 2.0 motor ?? the bore is not, the same I think ?
Old 12-18-2003, 05:43 AM
neilca's Avatar
The head gasket type is different. See my post on converting a 2.2 to a 2.0 on this forum. I still haven't gotten an answer on which head gaskets or modifications would be required.
Hopefully someone knows,
neilca
Old 12-18-2003, 06:58 AM
thor's Avatar
then it seems that 2.0 and 2.2 heads are plug&play if i can say
Old 12-18-2003, 07:59 AM
thor's Avatar
In an other post , someone told me to put a head of 2.2 instead of modify my 2.0 head to put larger valves like 2.0 S .
Old 12-19-2003, 12:57 AM
jluetjen's Avatar
what is the overall goal?
Thor, to put it another way, why do you want to put in larger valves? Do you have a HP target in mind that you are trying to get to? If so, you may be able to get there without changing the valves. Or it may make more sense (HP/$) to just convert to a 2.2.
The options are endless.
John
'69 911E
Old 12-19-2003, 04:24 AM
