Is this a 76 2.7 case?
OK, Finally got another picture for you guys to look at.
I have a 2.7 that I'm rebuilding. I think it has a '76 case even though my car is a '74. When I tore it down I noticed that the pressure relief pistons were the 76 and greater ones with the 76 oil pump. I'm trying to work out whether I need the oil bypass mod and now I'm thinking I do not. Take a look at this picture and give me your thoughts. http://forums.pelicanparts.com/uploa...1073153435.jpg Thanks, Tristan |
That looks a lot like my case, no mod needed. My case has a 74 nr, but is actually a later replacement case. It also featured the new oil pressure reliefe pistons and pump.
http://forums.pelicanparts.com/uploa...1073154275.jpg |
Your case also should have the hole in the bore identified by the arrow.
http://forums.pelicanparts.com/uploa...1073154705.jpg |
Peter,
Thanks for the confirmation. Yes, mine does have the hole through although it feels a lot like a slot. Tristan |
| All times are GMT -8. The time now is 11:44 PM. |
