Author of "101 Projects"
Wayne 962's Avatar
Pelican Parts WOW - Smokin' Deal on Mahle Nikasil Big Bore Cylinder Kits (2.5/2.9/3.5)
I just got a sale notice from one of our suppliers, offering some smoking deals on these piston & cylinder sets from Mahle. They appear to be clearing out their inventory. I bought mine last week from Andial for well over $3K, my cost!!! These are now offered at about $1000 off of retail. If you know what these are, then you know that these are smoking deals, and they will be good *only* while supplies last. Okay here they are:
2.7 liter to 2.9 liter 93mm Mahle Nikasil Piston/Cylinder Set, for CIS Injection, 9.2:1 Compression Ratio $2495 SALE (reg $3655)
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&mh=20&view_records=yes&uid=default&description=PS93-001
2.5 liter 86mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.3:1 Compression Ratio, for 70.4mm crankshaft - 911 IMSA-GTU legal $2595 SALE, reg $3595
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS86-001
SMOKIN DEAL:
3.2 to 3.5 liter 100mm Mahle Nikasil Piston/Cylinder Set, for Carburetors / Mechanical Injection, 10.5:1 Compression Ratio $2595 SALE, reg $3699
Click Here: http://www.pelicanparts.com/cgi-bin/dbsql/db.cgi?db=partsearch&view_records=yes&mh=20&uid=default&description=PS100-001
Again, I only have access to a few of these at these prices!
-Wayne
Old 06-13-2003, 01:24 PM
Wayne 962's Avatar
I also have these sets. Call Tom at 1-888-280-7799 (ONLY TOM) extension 221 if you wish to buy one of these:
PS98-007 3.0 to 3.2 liter (98 mm), 7.5:1 911 Turbo thru 77 $2695
PS100-005 3.3 to 3.5 liter (100 mm), 7.0:1 911 Turbo 78 thru 92 $2795
PS100-008 2.5 to 2.8 liter (100 mm) (Stroker Engines) 944 Turbo $1100
PS100-010 2.5 to 2.8 liter (100.5 mm),(Stroker Engines) 944 thru 88 $1100
PS102-001 3.6 to 3.8 liter , 102 mm bore/109 mm sleeve, (Machine In) 12.5:1 Carrera (993) 95-98 $2995
PS102-002 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 11.3:1 Carrera (964) thru 94 $2895
PS102-003 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 11.3:1 Carrera (964) thru 94 $2895
PS102-009 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 9:1 911 Turbo 93 thru 94 $2895
PS102-010 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 9:1 911 Turbo 93 thru 94 $2995
PS102-011 3.6 to 3.8 liter, 102 mm bore/107 mm sleeve, (Slip In) 8.5:1 911 Turbo 93 thru 94 $2895
PS102-012 3.6 to 3.8 liter, 102 mm bore/109 mm sleeve, (Machine In) 8.5:1 911 Turbo 93 thru 94 $2995
-Wayne
Old 06-13-2003, 01:46 PM
No Expert
jgparker's Avatar
Wow, those are great prices. Anyone know if the 2.9 liter 93mm set for CIS can be used with carbs and S-cams? (Wishful thinking)
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 06-13-2003, 04:10 PM
350HP930's Avatar
Single Cylinder Availability
Do you break sets for the purpose of selling single cylinders?
Old 06-13-2003, 08:02 PM
Forced Induction Junkie
WERK I's Avatar
Wayne,
Why can't the following part number be used on the 3.3l turbos? It would net a 3.4l displacement for that engine.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-14-2003, 01:11 PM
Drive it like u stole it.
jonesb930's Avatar
Wayne,
Thanks for the tip on the P&C sets. I called Tom today and ordered your last set for the 3.0-3.2 Turbo. I have a question for you, I understand that the 964 cams are good for CIS Turbo's. I am going to run EFI and was wondering what your recomendation on a camshaft would be? It is not going to be a daily driver by any means. It may see an ocasional day at Sebring for a PCA event. I basically want as much power as I can get while maintaining a decent drivability factor for the street. My goal is in the 500HP range. I also would like to ask your opinion on a clutch to handle this power. I have the OEM setup now (aluminum PP, Steel Flywheel, stock clutch). Would I be able to just have the PP and FW refinished and add a new performance disk? What do you think about lightening the flywheel?
Here is my setup:
Original Configuration:
930/50 3.0L Turbo (6.5:1)
Upgrades:
3.2L P&C
Andial K27 Turbo
Knife edge Crank
Boattailed Case
Shuffle Pinned Case
Case opened for larger (C2) Oil Pump
C2 oil pump
Carrillo Rods
Heads Ported to 41mm
Valve Job
New Performance Valve springs
3.2L intake ported to match heads
72lb Injectors
75mm Throttle Body
C2 Intercooler
Euro Exhaust
Tec3 Engine Management
Any help would be great!
Bill Jones, Jupiter FL
Old 06-20-2003, 04:38 PM
canna change law physics
red-beard's Avatar
Are any of the P&C's for upgrading a 2.2 engine still available?
James
Red-beard for President, 2020
Old 09-01-2003, 11:41 AM
red-beard's Avatar
James
Old 09-02-2003, 01:00 PM
anh911's Avatar
what kind of profile do these pistons have? Anyone have a pic?
thanks
Did I really post this? Even I don't know what I meant...
anh911
'94 Dakota - Meh
'98 Moto Guzzi - woo hoo
911; XJS; Islander 36; All Sold
'97 YZF1000RJ - Totaled (Not by me)
Old 01-05-2004, 07:15 PM
