70SWT's Avatar
heat exchanger swaps
Any simple rules on which heat exchangers will fit which models - maybe a chart or something? In my case, I have a US 2.4L 1972 911T, trying to figure out which ones off of other year 911s will fit and which won't. Thanks Al
2018 911 Carrera coupe
1972 911T targa
Old 01-16-2004, 10:20 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Alan,
For best performance any Heat exchangers from 67-74 will work just fine along with SSI's (don't know which flange you need though). Bursch headers will work but they don't have the thermostat take off that the MFI needs. I know that carrera HE's will fit but it's a real pain and kills performance(don't ask how I know)
Tim
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-16-2004, 10:52 AM
70SWT's Avatar
I also know of a 1975 2.7 liter engine available, also in need of heat exchangers. I assume the 75 and up are different due to the fuel injection system changes and/or flange changes...?
1972 911T targa
Old 01-17-2004, 08:36 AM
Tim Walsh's Avatar
A 75 2.7 I belive has thermal reactors which is overall a very restrictive system. It would be cheaper/better to go with a set of bursch headers over the 75 exhaust. It's about the worst system out there. It tends to overheat the motors and the flow design is really lousy. It would probably bolt right up but you really don't want it.
Tim
1973 911T
2005 VW GTI
Old 01-17-2004, 01:19 PM
