-   -   Case Washers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/144531-case-washers.html)
NevenM 01-18-2004 04:47 PM
Case Washers
Hi
What sort of washer are on the Nyloc Nuts around the case?
The part no I can only guess is 900 031 014 30 (from the
ones that hold the cam chain boxes on, They are not shown on
the crankcase diag on PET), but are the just a flat 8mm steel
washers?
Neven
dtw 01-18-2004 05:19 PM
8mm aluminum crush washers
NevenM 01-18-2004 09:54 PM
Thanks, Do you know the dimensions or of an alternative supply to porsche as 12c each.
Neven
73 911E, 70 914/6
Wayne 962 01-19-2004 02:29 PM
We sell packs of these in our rebuild section:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_enginR_pg2.htm#item6
You can also use the ones from a gasket kit that includes the hardware.
-Wayne
NevenM 01-19-2004 02:35 PM
Wayne
I called Wurth here in NZ, they have 8x14x1.5 are
these OK
Neven
davidl 01-20-2004 12:13 PM
Hello ythere.
No they are not aluminium.. they are magnesium alloy and much harder than the usual Al. available.
If you use Al, they will crush after install and you will likley get leaks..
Kind regards
