-   -   Case plugs? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/146663-case-plugs.html)
Ho Hum 74 02-01-2004 11:51 AM
Case plugs?
When cleaning my case, the machine shop removed two case plugs to clean the oil galleys.
Can anyone tell me where I can buy replacements?
Tristan
ChrisBennet 02-01-2004 05:42 PM
Once I had my machinist make them another time I had the machinist put in threaded plugs.
-Chris
Wayne 962 02-02-2004 12:52 PM
If you know the part number, you can type it into our search engine at the top of this page, and it will tell you if it's still available.
-Wayne
ChrisBennet 02-02-2004 03:16 PM
I don't think they have a part #.
-Chris
neilca 02-03-2004 04:11 AM
Why not use the threaded plugs? Seems they are more secure than a pressed in plug with epoxy on the outside.
350HP930 02-03-2004 09:29 PM
I am a big believer in using threaded plugs after the old press in kind have been taken out.
Ho Hum 74 02-04-2004 10:54 AM
Does anyone know the part numbers?
ChrisBennet 02-04-2004 11:23 AM
There isn't one. It's not a "part". It's part of the case that just happens to be removable.
-Chris
Ho Hum 74 02-05-2004 09:21 AM
Chris,
I agree, it's just that Wayne made it sound like there was....oh well, maybe he didn't read the question.
Where did you get the threaded ones?
Tristan
Wayne 962 02-05-2004 12:36 PM
Very often, with parts like these, Porsche makes replacements that do indeed have a part number. You can sometimes find them on the parts diagrams - they typically don't have a photo or number on the drawing associated with them. A prime example would be a master cylinder rebuild kit - it's on there, but you have to look for it.
Just like the piston squirters - they come included in the case, yet there is a separate part number for them. Another example would be the covers on the end of the cam towers. These also come installed, but are also available separately too.
That is what I meant - I just didn't have hours to try to find the part number (from the old parts books). Yikes, everyone seems to be on my case today...
-Wayne
Ho Hum 74 02-05-2004 02:08 PM
Wayne,
You're being too sensitive :) I guess you're just too used to all the kudos and accolades.
So, the big question is: if I call Pelican will the reps know the part #?
Tristan
CliffBrown 05-06-2004 07:39 PM
Tristan
Did you ever find a source or part number for the oil galley plugs?
Ho Hum 74 05-06-2004 08:46 PM
Cliff,
Thanks for asking. I did not. I just got my machine shop to make some plugs and fit 'em. About $50.
Tristan
