Ho Hum 74's Avatar
Case plugs?
When cleaning my case, the machine shop removed two case plugs to clean the oil galleys.
Can anyone tell me where I can buy replacements?
Tristan
Old 02-01-2004, 11:51 AM
Irrationally exuberant
ChrisBennet's Avatar
Once I had my machinist make them another time I had the machinist put in threaded plugs.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-01-2004, 05:42 PM
I don't think they have a part #.
-Chris
Old 02-02-2004, 03:16 PM
neilca's Avatar
Why not use the threaded plugs? Seems they are more secure than a pressed in plug with epoxy on the outside.
Old 02-03-2004, 04:11 AM
350HP930's Avatar
I am a big believer in using threaded plugs after the old press in kind have been taken out.
Old 02-03-2004, 09:29 PM
Ho Hum 74's Avatar
Does anyone know the part numbers?
Old 02-04-2004, 10:54 AM
There isn't one. It's not a "part". It's part of the case that just happens to be removable.
-Chris
Old 02-04-2004, 11:23 AM
Ho Hum 74's Avatar
Chris,
I agree, it's just that Wayne made it sound like there was....oh well, maybe he didn't read the question.
Where did you get the threaded ones?
Tristan
Old 02-05-2004, 09:21 AM
Author of "101 Projects"
Wayne 962's Avatar
Very often, with parts like these, Porsche makes replacements that do indeed have a part number. You can sometimes find them on the parts diagrams - they typically don't have a photo or number on the drawing associated with them. A prime example would be a master cylinder rebuild kit - it's on there, but you have to look for it.
Just like the piston squirters - they come included in the case, yet there is a separate part number for them. Another example would be the covers on the end of the cam towers. These also come installed, but are also available separately too.
That is what I meant - I just didn't have hours to try to find the part number (from the old parts books). Yikes, everyone seems to be on my case today...
-Wayne
Old 02-05-2004, 12:36 PM
Ho Hum 74's Avatar
Wayne,
You're being too sensitive I guess you're just too used to all the kudos and accolades.
So, the big question is: if I call Pelican will the reps know the part #?
Tristan
Old 02-05-2004, 02:08 PM
Old Member
Tristan
Did you ever find a source or part number for the oil galley plugs?
Clifton Brown
https://www.mancalamarketing.com
Old 05-06-2004, 07:39 PM
Ho Hum 74's Avatar
Cliff,
Thanks for asking. I did not. I just got my machine shop to make some plugs and fit 'em. About $50.
Tristan
Old 05-06-2004, 08:46 PM
