Cam Thrust Plate Removal
Guys,
Trying to get the cam thrust plate removed. Wayne's book says O ring is there and will offer "some resistance" but I can't seem to be able to pry this d*mn thing off. Any help will be appreciated.
72 911 Targa VTK Member 110245 71 911 Targa 68 911 non sunroof Coupe Gruppe B # 3911 http://www.pelicanparts.com/gallery/cassidyp |
GAFB
It offers lots of resistance. I use the cam itself to pop the thrust plate off. You can screw an old sprocket to the cam and then carefully pry under the sprocket. Cam and thrust plate should start coming out.
The above assumes all the rockers are off!
Several BMWs |
You can also push it out from behind if you have long, skinny fingers.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
removed
Thanks guys. Wayne's book is getting a little dirty, but I started removing the heads and it loosened up the part up allowing it to come right out. Thanks again.
you can see the back side of the plate where it seals to the cam tower. pop it out with a screwdriver by levering it off the cam tower. don't force anything between the tower and the plate, just pry against the exposed flat part.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 02-09-2004 at 08:36 AM.. |
Author of "101 Projects"
I use a pick that I inserted inbetween the plate and the housing, into the old seal...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
