Insane Dutchman
What size of TWM Throttle body to use?
Hi, just doing the planning for my next engine. It will be based on a 930/03 case, using the 98 mm Mahle P/C combo with the stock SC crankshaft, S cams. Car will be dual plugged and will have SSI exhaust, single outlet muffler.
Car will be a street machine, perhaps occasional track days, but will primarily be used for touring around in my "twilight years" which are rapidly approaching. Intent is to use the TWM "Weber carburetor replacement" throttle bodies along with something like a TEC 3 engine management system. Any advice as to the proper diameter of throttle bodies to select for best all around performance? Thanks Dennis |
No Expert
Wow, that TWM throttle body set-up looks great. Can I ask how much you expect the TWM TB plus the TEC3 FI to cost?
Thanks, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
No Expert
Sounds like a very nice setup, wish I knew the answer but keep us apprised.
Stay away from my Member
Richard Clewett would be good to chat with re. your planned setup. He sells the parts and should have a good idea of what works well with what engines.
http://www.clewett.com/ No affiliation, just passing along the info...
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Navin Johnson
heres mine (shameless pic plug)
sizing isnt as critical with throttle bodies as with carbs...no venturi 44 should be fine...if not 48's.. last time I talked with TWM the 44's were a few weeks until they made some more..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Insane Dutchman
I guess I was planning on using the 3003 series which is at - http://www.twminduction.com/ThrottleBody/ThrottleBody3006-FR.html - which says they are available in 40, 44, 46 and 48 mm sizes. The inidividual throttle body set up is indeed gorgeous, but more than what I need and definitely more pricey...although sizing ought to be the same.
1975 911S with Kremer 3.2 1989 911 Carrera Project Car |
Author of "101 Projects"
Use the 46s. For street driving, they might even be too big, but they are the smallest you can get.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Navin Johnson
available sizes 40,44,46,48 Quote:
all of the above are from the same castings..
Dennis, take also a look at this company http://www.jenvey.co.uk, the price seems reasonable.. and they have a couple of distributors in Canada...
My next year (or so) project goes along the same lines as yours... but I will be using the MegaSquirt engine management. Keep us posted!! regards
Jordi Riera '84 930 (modified) |
The 3006 featured in the link (which I was referring to) above is only available in 46mm.
-Wayne
