cassidyp's Avatar
Cam Thrust Plate Removal
Guys,
Trying to get the cam thrust plate removed. Wayne's book says O ring is there and will offer "some resistance" but I can't seem to be able to pry this d*mn thing off. Any help will be appreciated.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 02-08-2004, 02:22 PM
dtw dtw is offline
GAFB
It offers lots of resistance. I use the cam itself to pop the thrust plate off. You can screw an old sprocket to the cam and then carefully pry under the sprocket. Cam and thrust plate should start coming out.
The above assumes all the rockers are off!
Several BMWs
Old 02-08-2004, 03:15 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
You can also push it out from behind if you have long, skinny fingers.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 02-08-2004, 04:06 PM
cassidyp's Avatar
removed
Thanks guys. Wayne's book is getting a little dirty, but I started removing the heads and it loosened up the part up allowing it to come right out. Thanks again.
71 911 Targa
Gruppe B # 3911
Old 02-08-2004, 06:50 PM
you can see the back side of the plate where it seals to the cam tower. pop it out with a screwdriver by levering it off the cam tower. don't force anything between the tower and the plate, just pry against the exposed flat part.
206 637 4071
Old 02-08-2004, 08:11 PM
