Limbo
Slider79SC's Avatar
Are these dents too bad???
Aw crap......
Valves hit the pistons and dented them fairly good.
What do you guys think, can I clean up the dents and leave the pistons alone or do they need to be replaced.
This is not a race motor just used for DE's and street.
Let me know your opinions..
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 02-12-2004, 10:54 AM
No Expert
jgparker's Avatar
Some people pay to get valve pockets like that cut into their pistons, and you got them for free. I'll bet your exhaust valve are trash though.
Good luck,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-12-2004, 02:11 PM
You might want to make sure that the top ring groove was not distorted and that the top ring still has proper side clearance.
Old 02-12-2004, 02:29 PM
A friend of mine over-reved his engine and bent the valves. I didn't get a look at the pistons but he didn't touch them and just put the engine back together with new valve job. Engine has run fine for about 4 race weekends.
I would pull the pistons and clean them up and look for damage/wear. If they checkout OK then I would reuse them.
Old 02-13-2004, 11:54 AM
Senior Member
Superman's Avatar
I agree with Eagledriver. Your valves are junk. The pistons can likely be reused.
Mocha 1978 911SC. "Coco"
Old 02-13-2004, 12:40 PM
Author of "101 Projects"
Wayne 962's Avatar
Check the piston carefully where the wrist pin meets. The rod pushing into the wrist pin, pushing into the piston, pushed them into the valves. There is another thread on this forum right now of a piston failure that may have been caused by an overrev like this...
-Wayne
Old 02-14-2004, 12:07 AM
