nikasil texture
I have some used nikasil cylinders. the original crosshatch is still clearly visable. I've cleaned them up with some brake clean and the texture is smooth as glass. is this good? will the new rings seat? what is the texture of a new nikasil cylinder?
big AL '77 911 |
Friend of Warren
Alan, I just rebuilt my 3.2 with nikasil cylinders and like yours I could see the crosshatch and they were also smooth as glass. Upon the advice of Wayne and others I used a flex hone (grape hone) and ran it 4-5 times up and down each cylinder to insure the rings would seat.
Kurt V No more Porsches, but a revolving number of motorcycles. |
after running the flex hone were they less smooth? could you feel a change in texture?
what type of lubricant did you use when honing?
big AL '77 911 |
Author of "101 Projects"
Seeing the original cross-hatch is a good sign. Not seeing any scuff marks from the piston skirts is also a good sign. If both of these are true, then you can probably reuse these cylinders with good results.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
