Tricky D's Avatar
2.8 short stroke question re: rods
Which rods do I use, the 2.2 rods that go with the short crank, or the 3.0 rods that go with the pistons?
Old 02-14-2004, 05:01 PM
Stressed Member
Scott Clarke's Avatar
A 66mm crank requires the use of the 2.2 or 2.0 rods. The distance from the wrist pin to the top edge of the piston is the same regardless of application.
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 02-14-2004, 10:44 PM
Tricky D's Avatar
Thanks Scott. Fortunately I have the rods, just need to get them reconditioned.
Gruppe B #030
Old 02-15-2004, 05:27 AM
Tricky D's Avatar
Wayne,
What makes the 76-77 case so special, i.e., how do they differ from later Euro Carrera cases?
Gruppe B #030
Old 02-15-2004, 02:20 PM
Author of "101 Projects"
Wayne 962's Avatar
Originally posted by Tricky D
Wayne,
There is no other "European Carrera" per se (I guess you can call the 3.2 European versions a Euro Carrera, but no one does).
The 1976-77 Euro Carrera and Turbo (Carrera) had an aluminum case that can accept any crankshaft from 1965 through 1977. This allows you to plug this engine into any 914-6 or early 911 without any modifications to the transmission or clutch setup. This also allows you to build a short stroke 3.3 for use in these cars, or a short stroke 2.8 as detailed here.
It's a very rare and useful engine case.
-Wayne
Old 02-15-2004, 02:40 PM
Tricky D's Avatar
Thanks for the insight Wayne. Perhaps you might consider adding this explanation to future editions of the book (or did I just miss it)?
Gruppe B #030
Old 02-15-2004, 02:52 PM
Tricky D's Avatar
Wayne -
One other thing, if I may. Are there any particular case numbers I should be looking for, like 930/52, 930/02, etc.?
Thanks again for indulging me.
Rich
Gruppe B #030
Old 02-15-2004, 02:54 PM
Wayne 962's Avatar
Yes, you did miss it. See page 112 at the bottom.
-Wayne
Old 02-16-2004, 04:34 PM
Wayne 962's Avatar
Wayne -
Rich
See Appendix A for the list of the Euro Carrera and Turbo Carrera engine cases. When I found my Euro Carrera engine case at Pomona, I had to run back to my booth to get a copy of my own book to look it up!
-Wayne
Old 02-16-2004, 04:35 PM
