Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Aluminum vs Magnesium Cases
Assuming this is true, when do you decide to go into the bottom end of a magnesium case? I can see the need due to spun bearings, or other obvious damage but how about when there is no damage indicated? As I stated before, I "took a chance" with my 116,000 mile engine and did the only the valves. There is not indication that I needed to go further. How would I tell if more work is needed? Also, if I do need to go into the engine again, for the next 50,000 miles or so, can I "get by" with gaskets, rings, and machine work on the bottom end and leave my heads alone?
Let me add some more. My thoughts on the bottom end are based on the fact that you can tear it down quite easily when it's out of the car. An aluminum case *should* not require any machine work, although your Euro Carrera may not have the updated oil pump in it (I can't recall if the switchover was mid-year 1976 or if any early 1976 cars squeeked through with the old pump).
You can tear down the bottom end and measure/inspect the bearings. I know people who have reused bearings if they measured 100% in spec. While I wouldn't do it on my own engine rebuild, it's difficult to argue against keeping parts that are still in spec. It gives you a good chance to measure and check your rod bearings, and your intermediate shaft bearings, which seem to wear on these engines (they are only $30 or so to replace). So, an alternative option would be to tear down the bottom end, inspect, and reuse any bearings (after measuring them with the case bolted back together, minus the crank) if they all meet the specs. This is not what I recommend, but it's not a horrible path either. At least you know what's good and what's bad in the engine, and might be better than simply ignoring it. Then again, it might be perfectly fine in there, and the bottom end may last another 100K. If it were me, I would take a look, but I typically want everything to be 100% perfect. -Wayne
From this I would surmise the cost difference in doing a full rebuild is $500 for a 3.0/3.2L aluminum block engine and $2,000 for a 2.xL magnesium case engine. This is a hefty jump in cost and for us early eninge owners, we may choose to defer the extra cost. Funny how a few blind guys can describe an elephant so differently.
