Top-end Recommendations
OK, I've done my homework and read the assorted texts. Still I have a copule questions, since Wayne's book is really slanted towards a full rebuild. I intend only to do the top end. This is largely for cost measures and trying to avoid all the "while you're in theres."
My car is a 1976 Carrera 3.0 with about 100k on the clock. It smokes like mad and has all the typical symptoms of bad valve guides. It had a good leak down a year or so ago though. Here's what I intend to do in my top-end followed by questions: 1. Pull engine, clean exterior and pull off heads. 2. Have heads machined and new valve guides/springs/valves (as necesary) replaced. 3. Pull pistons & cylinders and replace lower Dilavar studs 4. Inspect and regrind cam to 964 profile. 5. Replace things like internal thermostat seal & oil pressure sender. 5. Leave the bottom-end alone 6. Reassemble & drive like hell Questsions: 1. Any more must-dos? 2. Pistons & Clyinders should be removed in order to relace the head studs. Should I pull them together and not pull them apart? Also, how do you do this without contaminating the inside of the case with gunk? 3. Related to #2. Should I simply re-ring at the same time? 4. Related to #3. If just re-ringing Nickasil cylinders, can I just grape-hone them myself? I really don't want/can't replace them. 5. I don't even intend to pull the pressure plate unless the clutch seems really thin. Are there any other accessable seals there are "must-dos?" Any advice would be appreciated. I am on a tight budget though. Chris |
Your car, your choice, but a question. Why are you pulling your jugs? Do you have leakdown and compression data to support this extra effort? If you re-ring, you will need to be careful to ensure the rings seat properly. Why take the risk if you do not need to do so?
Assuming you have ok compressio/leak down results, an alternative approach would be to pull the heads and inspect the cylinder bores for evidence of damage. You may find that that you do not need to rering. As far as other whle you are there's, I think you have a few seals on the crank shaft that you can replace. Like I said, your car, your choice, but an idea to consider. |
The oil pressure sender is the big sensor just to the right of the fan. The oil pressure switch is the little sensor on top next to the breather hose. -Chris |
My C3 at 115k miles had similar symptoms. The final straw was the broken head studs. When disassembled the piston/cylinder/ring assemblys were found to be well within spec, as was the bottom end, but valve guides were shot.
If you are planning to keep that engine I would plan on 12 new Manganeese Bronze or Silicon Bronze guides. 12 new valves, use Carrera Clubsport intakes and 930 exhausts, Smartracing valve spring kit, a sportier cam of your choice(talk to the cam grinders), and if budget allows some 98mm ~9:1 piston/cylinders |
Harry -- I'd rather not do the rings, but it seems like a prime "while you're in there thing to do" If, at 100k, it shouldn't be necessary, I'd like not to deal with it. However, I need to replace the bottom studs, so I assume I need to pull the P&Cs, but may not need to separate them if I'm not re-ringing.
Chris-- yes, Switch, not Sender (monday morning post). Bill-- I plan on new valve guides, of course, in the head rebuild. I really don't have the $$ right now for new P&Cs or hotrod valves. Any low(er) cost suggestions? So I guess my main question is -- is it sensible to be pulling the P&Cs to do head studs and not do rings? |
I would recommend doing the rings, and including the bottom end as well. Talk to Noah - his intermediate shaft bearings were toast (I think it was him), when he tore down the bottom end. It's like driving all the way to the grocery store, but not going to the drug store next door because you don't feel like it. The bottom end is the easiest part.
-Wayne |
Harry,
You can pull the cylinders with the pistons still in them by not sliding them all the way out-just far enough to pull the wrist pins. I've pulled two engines apart now and both sets had rings and pistons well within the wear limit. You shoul pull the pistons out (or at least one of them) and check the side clearance and end gap. The specs are available in lots of books. The numbers for my 2.7 were .004" for side clearance and something like .030 for end gap. My end gaps were exactly half of the wear limit. My opinion and the opinion of my machine shop is that it is safer to use the old rings if they are well within limits than take a chance on new ring break in problems on the old cylinders. I think you will save a lot of money by not splitting the case (assuming good oil pressure and no leaks). -Andy |
While it can be see to be prudent to do it all, the original poster pointed out that he was on a strict budget. Also, a top end will cost a person $3,000-5,000, if done by a shop. A full rebuild, in a shop, is on the order of $10,000. This is not an insignificant difference. On th eother hand, if you DIY, the cost of parts and machine work for the top end is about $2,000 and about $3,500 for a total rebuild. This may be close enough to justify the additional work. If he is like me and drives 5-7000 miles a year and gets 20,000 miles out of his top end, he gets 3-4 years of driving before he needs to do the bottom end. At that time, chances are that he will not need to redo the heads. While he will incur the cost of R&R'iong the engine and teardown twice, he gets to spread his cost over a longer time with little increased risk. Of course, it is a gamble but it may be one he is willing to make. As always, YMMV. |
There really is no such thing as a "911 Engine Rebuild on a budget." -Wayne |
Wayne,
With all due respect, you points are well taken. As you very correctly point out, you need to know why you are rebuilding to define the scope of your work. As you, and others have pointed out, you are taking a risk by doing only a top end but that may be a risk some wish to take knowing full well it can come back to haunt you later. I was merely pointing out that you may decide to limit your scope, but you should still do some investigation/testing to avoid any obvious risks. Should you pull a cylinder and measure the ring lands? Yes. Should you pull a connecting rod to inspect a bearing? Sure! These may help you decide if you need to go further or take a chance and stop and wait for a later day. As you state, there is not such thing as a Budget Rebuild, but you may decide to limit your scope to buy some time. And as I did point out, when it is time to pay the piper, you will incur more total cost by doing two rebuilds than you would have if you did only one. Like I said, no disrepsect, just a different view on a common problem/issue. |
BTW,
Not to think I am toatally foolish. On tear down, bad news has been found. I could not find the one Wayne refered to but another example: http://forums.pelicanparts.com/showthread.php?s=&threadid=132097&highlight=valve+ guide |
-Wayne |
The valve guides and headstuds are the vulnerabilities. At a minimum in addition to guides replace all 24 head studs w/ the 993tt version. 993 101 170 51 |
FWIW, head studs can be replaced without disturbing the P/Cs. Some will advise against it, but it is doable. If you can break the red locktite without heat, you are home free. Replace the studs one at a time, and keep pressure on the cylinders at all times with the hold-down tool.
No comment on the wisdom of not touching the bottom end, but it will almost double your rebuild cost if you do crack the case, and the 3.0 carrera bottom end is fairly robust. Good luck, JP |
Nope, it sure will not double your cost. In fact, part of what Wayne and others are reporting is that the engine's bottom end is clearly the simplest part of the engine. Not much there to replace in fact, except the hardest working parts in your engine. The bearing shells. Measure (machine if necessary) the rods, and measure/inspect the crank, and you're into it for another $500, maybe.
Or you can wiggle the rods while the pistons are off, and see if there is play. If you split the case you will find some wear on the intermediate shaft bearing shells, and some wear on the main and rod bearings as well. The bottom end will survive, probably, if you don't split it. But if you do split it you will see, visually, the wear you are correcting. But these are tough decisions. Re-ringing is dicey. Sometimes the new rings won't seat. Or maybe the P&Cs are out of spec. Then again, refreshing the valves brings things out of balance. Valves that seal real well....rings that don;t. Like all who have gone before you, you'll have to make these decisions on your own, with no guarantees. The greatest guarantees are with the highest prices. The budget strategies have more risk. It works like a laxative. Wait'll you turn the key and start it up after reassembly. Makes bungee jumping seem tame. |
I'm a little disappointed that there seems to be no inbetween when doing an engine rebuild. I know that Wayne's book is "How to Rebuild..." your engine, not "How to Screw Up your Porsche Engine on a Budget" ;) but there have got to be acceptable varying degrees of commitment.
I'm not necessarily looking to cut corners and do this in a half-assed manner. However, there are realities of $$ at hand. It does cost more to go into the bottom end. The extra dollars involved make it cost-prohibitive for me to do anything otherwise. Still, I'm budgeting $3k to this and a few other well-needed upgrades. It'a amazing how quickly it goes when trying to do some things right. If I can get 20k miles out of this top-end rebuild, I'd be very happy. Then I'll do it again-- right. I also expect to be very happy with doing this myself. It's been great fun just finding my machine shop and talking to the people I'll be working with. That said, If I inspect things and don't find too many gremlins lurking within are there any more *must* do things? Thanks for the advice so-far. Chris |
It has been common practice to just do the top end on 911 motors for many years. The valve guides simply wear out before the rest of the motor. There is a good argument to be made for doing the bottom end "while you are in there" but I am not convinced that sky will fall if you don't. Sort of like your Dad telling you to stay away from red heads. He's probably right but still... :D
If this car will be going to the track I would either add racing valve spring to your list (more $) or skip the 964 cams. The 964 cams increase the likelyhood of valve to piston contact during a missd shift. -Chris |
Thank you Sir Bennet. Previoiusly, I was under the impression that there are top-ends done all the time. They seem to be the soft spot in otherwise solid engines.
c |
SuperMan,
Not to be argumentative, but my last bill from the machine shop for case work was almost as much as Chris has budgeted for his entire rebuild. Between the line-bore back to Std, case mods, case savers, spot facing, spigot boring, rod reconditioning, crank inspect and micro-polish, Plus round trip shipping from Florida (or Bolder) to California, my rebuild cost just about doubled. Now, if you skip all the machine work, then the cost of cracking the case is close to nothing, but I think that is ill-advised. I believe there are plenty of cases where a top-end only rebuild is a reasonable choice, especially given the short life of the valve guides from this period of 911s. Given Chris's situation, it may be a reasonable choice for him. Just my two cents. JP |
Fellow Pelicans,
I think this is great discussion. :) I would like to add a bit of spice to the mix. I think alot of the cost issues relate to the degree of machine work required. For the early engines, the magnesium cases tend to stress relieve over time. If you spilt the case, you need to machine the halves to get the faces to align properly on reassembly. Am I mistaken in thinking that the later, aluminium cases do not have this issue? Also, as JP notes, the valve guide materials have been improved over the years. I have heard that the ones used in the early 911 had an expected life of 50-60,000 miles. Hence, it is not uncommon for a top end only to renew the guides. |
I just re-read Wanye's ealier post commenting that if the engine had been abused badly enough to warrant a top-end at 100k, that there may likely be bigger issues.
For the record, this is a C3, which I believe has the crappy valve guides that were in the 2.7. For it to have made it to 100k in original form, with everything I know about the car, indicates that it was well cared for. I realize that the engine can contain all sorts of skeletons, and I'm not trying to turn a blind-eye to reality. One further question: If I pull P&Cs together and do not separate them, can you still clean carbon off the cylinder heads? If so, how? |
I'm not totally familiar with the lingo but what does keeping the P&Cs together have to do with getting carbon off the cylinder head? I don't see why You can't totally r&r the cylinder head without separating the pistons from the cylinder. Does it have something to do with remating them, one clean and one not?
In re-reading my post, I can see how what I was asking could be confusing. I'm not asking about cleaning the cylider heads, I'm curious about how to clean the heads/tops of the cylinders themselves. If they're still surrounded by the pistons, I wouldn't want to blast them off, nor would I really want to do anything to dislodge the carbon and potentially get gook in around the rings.
Maybe I don't clean them at all... |
I plugged the holes in the long block with a bunch of rubber stoppers and capped the intakes and exhaust with the old gaskets and blanks that I made and blasted it with a high pressure washer. 1. I wanted it clean for disassembly and 2 if I have the Alusil cylinders I don't want to separate the p&cs but wanted them reasonably clean since the heads will look new after the machine work.
Jim |
I don't see any down side in removing the piston assy. from the cylinder as long as you don't mix them up. Good time to check ring side clearance. The rings can also come off if you want to clean the pistons, just reinstall in the same piston and in the same orientation (not upside down).
Sherwood |
I tell you I'm spooked, Wayne's recommendation on this board and in the rebuild book is to leave them together and do not disturb if they are Alusils. I don't know what they are yet because I can't find a 46mm crowsfoot in stock, so I can't tear the rest of the motor down.
You're right, JP. I hadn't noticed the engine vintage. My case is AL, so machine work on the case costed exactly $0. I'd also agree that, given the age of the engine, leaving the bottom end alone makes sense.
P&Cs can be removed without separating, but you'll have to use heat to remove the wrist pins. When moist air gets onto the pistons tops, the carbon will flake off. It'll just falke right off, making a mess if you're not careful. Given some thinking and strategizing, you should be able to prevent those carbon flakes from causing trouble. This engine might be a good candidate for the kind of rebuild many of us try for, and fail. The true budget overhaul. In fact, why remove the wrist pins? Replace the guides and seals, perhaps valves if necessary, and button her up. Perhaps even if the valves are worn, with new guides, button her up and go. If you're just trying to get 20K miles, you should get that. |
While I'd be happy with 20k, I of course, would be happier with more... I do want to replace the head studs while I'm in there. So, I believe I'll need to pull P&Cs to have necessary access. We'll see where the budget ends up.
You think the carbon will basicall jump off the cylinder tops and that they'll be clean enough to reinstall without any sort of mechanical or chemical cleaning (enough being a relative term)? |
echrisconner,
Okay, I'm amending my recommendations. If you want to save a step, don't remove the rings. After separating the piston assy. from the cylinder, submerge it in a vat of carb cleaner overnight. Don't submerge the con rod big end with the bearing shell (which you will not want to remove either, right? Sorry). The next morning, the pistons should come out completely de-carbonized (the stuff that's going to come off easily anyway). Rinse in hot water, blow-dry, check ring clearance, re-lube, then reinstall. If you want to go to the trouble of removing all remnants of stubborn carbon from the top, follow up by completely masking the ring area and skirt, then have the tops glass bead-blasted. All this is assuming your rings are in good shape (good compression), cylinder walls pass inspection and you can't budget for new rings (maybe save up for this). The cyl. walls won't mind if the mating piston rings loose intimate contact for a few days. Mine were separated for many years with no apparent ill side effects (my extended assy. schedule). Go back to the leak-down test. Did the rings pass muster? Misc. thoughts: Comparatively speaking, the main bearings should last longer than the rod bearings. If your observations of engine history and condition look okay (oil changed regularly, engine not abused, etc.), leave the crankcase alone. But if you're going this far, you might as well check what's happening inside the cylinder. Mind you, this is not my definition or version of an engine rebuild; it's just a version. Sherwood |
I'll let you know as I went for the "budget" rebuild in hopes of decent life extension on my old gal. FWIW, I have had several respected experts tell me to expect not more than 10-15,000 miles but our inspection revealed no issues beyond worn valves and guides. I am at 3,000 miles and no signs yet. Ask me again after AutoX season. |
I would replace all the head studs w/ the latest 993.101.170.51 Porsche list ~$20. If you are concerned about one you should be concerned about all, age and corrosion arn't limited to only half of them.
I've read so many stud posts recently, I don't know what to think any more. I was thinking about doing just the lowers since they're Dilavar.
I've heard Wayne's recommendation for using the original Steel ones. I've seen another recommendation to use the 993 steel ones, now this recommendation for a different one still... Not sure what to think. |
993.101.170.51 are used on the 993tt/99RS and are the ones the Porsche Motorsports and most respected builders will recommend and use for their own projects.
I currently have several build sheets form different houses in front of me, everyone of them used 24 of those studs. I agree that there seems to be a lot of conflicting opinions on this topic you will just have to separate the wheat from the chaff by yourself. |
I'm in the same situation but I decided to go with the OEM steel. And after reading that 17 page post on Alusils I'm going to rering as well.
CE and Ollie's both said that my SC w/130k should only need the top end which I am doing due to a little smoke and broken head studs. CE was very certain about this!!
To respond to eagle driver post on his ring end gap, boy that is a lot. .030 for end gap is huge. So I guess you carry around some extra quarts of oil with you since half of it is coming up from that case past that gap. .030 ! thats spark plug gap , not piston ring gap!
I'm sure this has been discussed a million times before but, what is the opinion(s) on pulling the pistons/rings out of the cylinders. I believe you can take them off the rods w/o sepapration. Is this good/bad/indifferent? Have had many takes. Tell me yours!
Sure you can do it, but what's the point? You can't measure and inspect the pistons (and more importantly) the rings for wear. |
-Wayne |
| All times are GMT -8. The time now is 07:44 AM. |
