Snowman -- You and Me -- Mano e' Mano!
I've been thinking really hard about your comment that the early T/E heads with 32 mm ports are good enough for tons of HP and the S heads being all marketing for anything less then a race engine. Here's my logic as to why I doubt that you'll be able to get more then about 175 HP from T/E heads, no matter how fast you spin a 911 motor. An also why you do need S heads to get the HP up to around 210.
Let's start with the T/E flow data that you have published previously: Quote:
How long is an E cam open for at it's peak HP engine speed? About 0.000105983 seconds. How much air can flow through a 32 mm port in that time? ~.4 liters. (Note that I've assumed that the flow profile is like a trapazoid with 1/3 of the time at full lift, 1/3 on the ramp up and 1/3 on the ramp down. So the flow over that time would be equal to 2/3 of the flow * time: (1/3T + .5(1/3)T + .5(1/3)T) What is the capacity of a single 2.4 liter engine's cylinder? .4 liters. Hmmm.... :rolleyes: What happens if you put an S cam into that engine? Well the extra lift of the S cam won't provide any benefit over an E cam since an E cam's lift is .408 and an S's is .459 since a 32 mm port doesn't flow any more air at .459 inches of lift then it does at .408. But it does have more duration and overlap. At the same engine speed an S cam would have the valve open for 0.000114103 seconds. Going through the same math results in .43 liters of air being available for a .4 liter cylinder. So chances are the S cam would not quite be starting to run out of air at 6500 RPM like an E cam would. If you look at 6800 RPM where an S cam seems to peak, once again the ports would allow .41 liters of air into the cylinder which is within 3% of the cylinder capacity. Since the engine will be allowing full cylinder filling at a 5% higher engine speed, I'm guessing that maybe the engine will make 5% more HP or about 8.25 HP for a total of 173 HP. Keep in mind that you will lose some flexility at the bottom end since the torque peak will increase from an E's 6200 RPM to an S's 6500 RPM. Now I've always maintained that the 2.7RS (which uses an S cam) was also port constrained even though it was using 36 mm ports. Repeating the analysis with a 2.7 engine results in the ports flowing .44 liters at 6800 RPM into a cylinder with a capacity of .45 liters. This might explain why 2.7 RS motors don't make proportionally more HP at then a 2.4. The answer is because at peak HP RPM the cylinders aren't getting a full charge of air, thus the BMEP (aka: torque/liter) at that engine speed is less then a 2.4S's. Incidentally at an RS's peak HP speed of 6300 RPM, the ports will flow .48 liters of air into the .45 liter cylinders. http://www.pelicanparts.com/support/...s/thinkerg.gif |
Interesting analysis, John. So, would a 2.7RS benefit from slghtly larger ports (e.g., 37 - 38 mm)? And what, if anything, would be sacrificed? Thanks.
Just another thought here - you need to make sure that everyone is talking about the same thing. There many ways of measuring horsepower. Peak horsepower is typically at higher RPM, and really doesn't often mean much to the average street user. Low-end torque (available power) throughout the driving range is what often matters to most people.
For example, the 911 2.7S engine is rated at 175 HP, and the 3.0 is rated at 180 HP (peak). Yet these two engines feel very different when driving. Looking at the straight peak HP numbers, you would say there was only a 3% or so difference in them... My point? Arguments about flow rates of heads are really only applicable to high-RPM ranges where you're talking about peak HP - not really applicable to everyday street driving. -Wayne |
To make two extreme cases, first you could hypothetically attach heads with 32 mm ports up to a 3.6 liter engine and an E cam. This engine would generate it's full torque of 230 lb-ft. But it's peak HP of 176 HP would be at only about 4500 RPM. Above that speed and the cylinder wouldn't have enough time to fill. (Note that I came up with those numbers based on my previous observations that BMEP's at peak HP and peak Torque are very consistant for a given cam.) Anyhow, since most people drive below 4500 RPM 95%+ of the time, this would be an awsome motor with mountains of torque for a real kick-in the pants. But it would also be like driving a 911 with diesel truck motor since it will pull hard to 4500 RPM and then drop off fast. The other extreme case would be the 2.0 rally motor which used an S cam and 32 mm ports. At the S's peak HP speed of 6800 RPM, this engine's cylinder(s) need .33 liters of air while the 32 mm ports can deliver .41 liters of air. So even with 32 mm ports, the cylinders are getting enough air. The engine can't take advantage of the extra lift of the S cams, but the duration and overlap will still be of benefit. The result is an engine that generates almost as much HP as a 2.0 S's 170. In fact, with carbs these engines made 150 and with the extra 10 HP (rule of thumb) for MFI, you could expect close to 160. It might even pull a little better then an S at lower rev's given the extra intake velocity, but I haven't modeled that yet. Even with a 906 cam, the 2.0 engine with 32 mm ports should pull to almost 8000 RPM. You won't be making 906/911R HP though since you won't be able to take advantage of the extra lift. Where's that leave you? Maybe at around 190+/- HP. The conclusion is that smaller engines can take better advantage of a head's flow capacity since they are taking smaller bites of air. But even then, it's a case of deminishing returns since the engines can't make use of the additional lift available from the more radical cams. |
John-
That's great information. What is the math like if you assume that bk911's numbers are right? |
In the case of the 2.4E, the ports will be flowing the cylinder capacity at 5500 RPM.
I don't consider myself an expert on 911 head flow rates. However, I will make the following observations. All of the Porsche factory racing engines had large ports on them (906, 911R, etc.). I would think that the factory knew what it was doing when it designed those into the heads. Afterall, they won quite often back then.
-Wayne |
John,
That is a very interesting analysis. Let me include one more variable to your work. That is, the boundry layer of the flow increases as the speed increases. So as the speed of the air increases the port actually starts to choke itself off. Thus, the need for the larger port if you plan on high rpm operation. On the Sport 2000's I used to run we were restricted on the port size by the rules. The Weber 32/36 carb had a fuel tube from the float bowl to the throat of the carb. At high speeds fuel would be siphoned from the bowl into the throat to increase the intake mass, this I was told would decrease the boundry layer and allow more air to flow. At first I didn't believe this ,but then I thought "what good is more fuel without more air?" I disconnected this tube once and could really feel the difference. By the way this mod is illegal for IT classes, we checked!I have seen this mod done to IDF carburators as well. Just some food for thought, neilca |
Hmmmmn,
You say "If you look at 6800 RPM where an S cam seems to peak, once again the ports would allow .41 liters of air into the cylinder which is within 3% of the cylinder capacity. Since the engine will be allowing full cylinder filling at a 5% higher engine speed, I'm guessing that maybe the engine will make 5% more HP or about 8.25 HP for a total of 173 HP. " I will agree with the crude analysis you presented, but then ask the question ONLY 8 more HP AND you have to spin it higher than 6500 RPM to do it!!! ALL that Porting, All that money for WHAT?!!! 8 HP and a loss of torque at more driveable RPMs. Tell me again thats not marketing for a street engine. Using a more accurate method, eg engine dyno 2000, the actual cam profiles, the actual measured air flows, the difference becomes nothing. You did state an interesting bit of info. That someone measured the max airflow of the T heads at 150 cfm instead of 200. If this is true then there would indeed be a very big difference in power. From what I have seen of Porsche heads, the ones that measured 150 CFM must have come from a Chevy. Ie a lot of flashing left in the ports. It could be true, but I doubt it is true in general for a Porsche. |
I appreciate that you think the method is pretty rough cut, but how does the software that you mentioned describe that you can get there? What sort of engine configuration will allow "Big HP" (200 HP+) in a 6 cylinder, 2 valve per cylinder engine using 32 mm ports flowing 200 CFM? |
Just as a side note:
When I flow heads I don't use a bellmouth on the intake. Mainly for consistancy. I have used one to see the difference and the results averaged about 5% higher. That still doesn't get me near the 200 cfm range on a T head. Anybody else have flow data on any stock 911 heads? I'd like to compare and see how close my numbers are. The flowbench I use does get calibrated annually so I am fairly confident it is at least close. Maybe operator error? Wouldn't be the first time! BK Edit: I checked my notes. On an S head I was getting almost 10% more airflow with a bellmouth. |
I have picked the SC330 cams for my turbo project.
I will let you know how it turns out in a few months once its all together. |
The flow bench, a Superflow 600, also calibrated yearly. Also other heads have been flowed, ones with well known flow rates, such as chevy, ford, with results consistant with commonly accepted numbers, eg typical 350 head about 160 cfm unported, 200 to 225 cfm ported (depending on head and valves) AFR heads compare within a couple of percent of advertized figures. And yes the spark plug was in the hole and the leakage measured almost zero with valves closed. Clay was molded to a radius of 3/4 inch and fitted to the ports to smooth airflow. One last final note. I flowed my 912 Race car heads and the actual power to the rear wheels, measured with a dyno at sea level, temp 70 degrees F, Relative humidity 50%, 140HP at 7800 RPM, for 1725cc, 12:1 compression, cam 285 degrees at 0.050" lift, is right on to what Dyno 2000 using the measured air flows of the heads and the measured cam profile predicts. |
Snowman, While working out this morning I think I came up with a "real world" confirmation of your maximum of "lots more then 170 HP" claim for 32 mm ports.
The example would be the FIA restricter sizes. In 2003, NAV8 engines in the FIA series were limited to 2x33.1 mm intake restricters and made "around 600" HP. This is "around" 300 HP per restricter. So yes, it is possible to get 300 HP from a 33.1mm intake. The difference is that between the FIA restricters and the cylinders is a plenum which smooths out the pulses from the individual cylinders. Also when the engine is creating "around 600 HP", the air through the restricter is constantly at the sonic limit. In the case of a 911, there is one cylinder per 32 mm port with no plenum between the two. As a result the 32 intake port is seeing very strong pulses from the cylinder and it is the air flow during the pulse which is limiting HP rather then the average flow. An interesting idea that I've seen investigated on motorcyle engines is to create separate plenums of a specific volume for each cylinder. This would reduce the affect of the pulse through the restricted port and allow some additional HP. |
It sort of boils down to the following:
1. If you keep the displacement small, the RPM goes out of sight to get HP. You just can't maintain any driveability with large ports on a small displacement engine. 2. You increase displacement, so you can have much larger ports and a lot of HP at low RPM. Then you have a Chevy, not a Porsche. There is a company that sells Chevy conversions for Porsches. One more reason CA is on the decline. |
Just a little info for you guys to think about. This relates to Ford V8's specifically but can be of some use for the 911. Also I forget all the math involved in determining neccessary airflow for a given HP so I won't get into that.
Typically street/strip and pure strip heads are compared at .600" lift even though most street engines don't open the valves that far. 250-300cfm at 600 is considered good for street/strip and over 300 is a must for a strip only motor (small blocks 300-400 cubic inches). My drag motor produced in excess of 600HP with 315cfm at .600. Cam lift was .690 intake/.710 exhaust with duration of approx.301/309 at .050" lift. Engine size was 410CI with 4.040" bore and 4.00" stroke. That's close to 1.5HP per CI. What makes all this relevant to 911 engines is that most of them produce roughly 1HP/CI which, by most standards, makes them a high performance engine. Just popping a 3.0SC up to 225HP put's it in race engine territory meaning that street manners diminish. As Wayne stated earlier torque is usually better for street driving with one exception. If you have enough torque already then losing a little won't be as noticeable, this can be accomplished with a longer stroke (stroker motor) or forced induction. A good street head will have ample flow or area under the curve in the range BELOW peak cam lift because the engine only sees peak lift briefly and most of the cylinder filling occurs at lower lifts. A good head porter can improve low end airflow without going overboard add to that port matching the intake and exhaust and significant, streetable gains can be made. I personally have seen noticable (improvements in ET) with mild port work and matching even on aftermarket aluminum V8 heads with engines turing less than 6000rpm. Snowman's last reply is the real truth (kinda sad for us 911 guys) high HP in a 911 means high rpms, remember these are already performance engines and already peaky compared to a V8, the only serious streetable gains come from a swap to a larger motor. While I know that everyone's definition of streetable may be different take this into consideration. My drag car was a total blast at the strip yet a total pain on the street, anything below 3000rpm and the motor would buck and shake the whole car, above 3000 and with a little throttle and I couldn't keep the tires planted. Believe me driving around town in second gear above 3000 in no fun with a V8 and not a lot of fun in a 911 either (a big reason why I upgraded from a 2.0E with carbs to a 3.0SC engine) so unless it's a weekend warrior save the race heads for racecars and spend your money making the car lighter or the engine bigger. ;) |
A Quiet Boom has made a serious understatement when he said any street engine can flow as much as 300 cfm per cylinder. Stock V8 heads can flow as little as 160 cfm per cylinder, and as much as 225 cfm with light porting. Heavy duty porting and or race heads start in the 260cfm up catagory. and 300CFm is a race engine.
Of course real drag race engines flow as much as 600 CFM per cylinder, naturally aspirtated!!! Of course drag racers can't be satisfied with that so they supercharge it as well!!! At over 10,000 HP they stop counting. Funny thing is that a stock chevy with mild porting, the same duration cams as a Porsche, headers and good carb (and thats a 307 chevy, not a big block) makes over 400HP. But of course they break the first time one steps on it. |
My point about 300cfm on a race engine is geared towards V8's not 911 engines. Please note I put 300-400CI in parenthesis. A small block V8 has ample torque and can be driven with a mild cam and 300cfm ports. I seriously doubt the same of a 911 engine because torque is already at a premium. I'd bet 225cfm would be about max for a drivable 911 but given that 200 or less will get the job done there is little point. I do recommend port matching and a mild cleanup to get the airflow below peak lift a little higher, this allows less cam with the same cylinder filling or more cylinder filling without too much loss to the bottom end.
Nice thing about 911 ports, they need almost no port matching, almost no cleanup, in fact a stock 911 port would be considered "ported" if it were on a chevy or ford. The only significant thing I have found is a slight, and by chevy standards, I mean very slight, bump on the short side radius, the same short coming a chevy has but on one tenth the scale. Additinal porting on a Porsche is really port reshaping, a risky business. Most Porsches only benefit if ported to run at 7500 plus RPM, which basically means larger ports, poor low end performance, and peaky high end performance.
Don't get me wrong, even that "little" bump on the short end radius can yield another 5 to 10 percent performance on a Porsche (On a chevy or ford it could yield as much as a 40 or 50 percent increase, no sweat). But don't expect that chevy bang for the buck on a Porsche. |
Snowman, you haven't responded to my original observation. This discussion of SBC's and V8's isn't really germain (as opposed to German ;) ) to the discussion since the drag motors that you are talking about are completely different animals compared to a 911 motor.
Drag Motor............911 Motor .82 liters/cylinder.... .45 liters/cylinder Rectangular ports.... circular port cross section "Bathtub" chambers... Hemi head (OK, Hemi's have Hemi heads, but SBC's and Fords don't) Blown ..................... I'm discussing NA 911's, not Turbos Aside from both examples being internal combustion engines, they have very little in common and I don't see what it's adding to the discussion. Keeping to the subject at hand (NA 911 and 912 motors), do you see errors in my logic or the way that I'm looking at the problem? I'm trying to understand how to get over 200 HP from a 911 motor using 32 mm intake ports since I'm sure that there are a lot of people on this board who would like to know. Conversely, "if you cahn't get theah from heah" (as we say up here in New England), that's a good thing to know also. You have steadfastly maintained that you can get there (over 200 HP in a NA 6 cylinder engine with 32 mm ports) and I don't see a path to do so. Show me the way! What cam would you recommend? What cylinder size? Which head configuration (2.0 or 2.2/2.4?)? What CR? |
Quietboom;
Given the numbers that you supplied I've plugged your engine into my analysis and came up with the following results. I've assume a 6600 RPM peak HP engine speed. Flow at maximum lift: 315 CFM or 8920 liter/minute Time at full lift: ~ 4.20875E-05 seconds Avg flow while valve is open at 6600 RPM: .75 liters Cylinder capacity: .83 liters. I suspect that you are running a high CR of at least 10:1, is my guess correct? I also suspect that my baseline analysis doesn't take into account what I suspect to be some very significant overlap in your cam spec. Would you be willing to share that? |
CR was 13:1. I don't remember the exact cam specs since it was a custom Lunati grind and I'd have to dig up the cam card. Going on memory lobe separation was 108 degrees, cam was timed straigt up, and the overlap was over 40 degrees, basically it was the biggest flat tappet cam I could run before moving to a solid roller, again this is going on memory from 5 years ago. I used a ported Edelbrock Super Victor intake, custom 2" headers with 4.5" collectors. The car was a T-top body with a full cage so even stripped to the max it weighed in at 3200lbs. Best MPH was 132 and best ET was a dismal (due to traction and other issues) 11.01. The trap speed should have put the car solidly into the 10s like 10.5 or better but it was a real bear to hook up on 10" slicks and a 4spd. I shifted the car between 6800 and 7000 so your estimate of 6600 is pretty good.
As for the discussion of V8's I brought it up because airflow requirements for a given HP are the same for all engines and I just wanted to point out where I had some experience. IF I remember correctly 315cfm should have been more than enough for 600HP in theory but in the real world it rarely works that way. A quick look a 911 ports tells me that they are already a great design and snowman is right, you're not gonna get the same results porting them as you would a stock V8 head. I'd say they are more closely matched to high end aluminum V8 heads, gains can be found but with dimishing returns. The most important thing I've found in engine design is properly matching everything, choose an rpm range and HP target and size everything towards that goal. |
If you're shifting at 6800 - 7000 RPM, it looks like you're doing better then my model would suggest. I suspect that it is due to the large amount of overlap giving the air flow a "headstart" versus what the duration would suggest. Quote:
200 CFM through a T/E's 32 mm ports sounds high. A 351 Cleveland V8 example that I've seen (2.041 inch ports or 51.8 mm's) shows stock port flows of 182 cfm at .550 with an improvement at lower lifts after porting. A different example with 1.655 inch ports (42 mm ports) showed peak flows of about 151 cfm at .600 inches. Both of those ports I assume are rectangular and are quite a bit bigger then 911 ports, but it doesn't make sense that the 911 port flows that much more then them when you could fit a 911 style port inside either of those examples with room to spare. If that were really the case Detroit would most likely have done that at some point during the 50 year career of these motors. So, I guess this whole excercise falls apart for one or more of the following reasons (or maybe some which aren't mentioned). 1) HP does not coorelate well with head flow (at least not linearly). 2) The 600 HP is not a real number. 3) 32 mm T/E heads do not really flow 200 CFM 4) You can't compare V8 style heads with 911 style heads because the flows (and resulting combustion) have completely different charactoristics. 5) ...? Either way the model does seem to fit reasonable well within the set of 911 motors. I do question if Snowman's flow numbers are somewhat optimistic. I also suspect that in fact the engines will be ingesting 100% of their volume closer to the peak torque engine speed rather then peak HP engine speed. Oh well, back to the drawing board... |
Yup, I should have stated 315 per cylinder. The flow requirements of a 6 would be higher. 600HP IS NOT a real number, it's derived from MPH in the quartermile vs. vehicle weight for RWHP, I multiplied by 1.1 for an approximation of the flywheel HP. Now that's the math, here is what an expert told me after I twisted the crankshaft and I quote "you need to make in excess of 650HP to twist that crank 4 degrees!" I didn't believe it then and I don't believe it now. I have to assume that as HP and torque go up that the driveline loss as a percentage gets smaller, add lightweight or high performance diveline components I it should go down even more. Basic phyics says that I'd have to make 575HP at the rear wheels to hit 132MPH in the 1/4 mile so lets assume it's just 600 at the flywheel that's roughly 1.5HP/CI or about 88HP/liter which would be roughly 265-270HP for a 3.0 911. Now 1.5HP/CI naturally aspirated is nearly impossible to street drive, perhaps a high tech engine management system might make it better but still it would be finicky. Add to that the fact that drag race V8s have two advantages over 911s from a power output standpoint, the first being water cooled heads which allow higher compression and second they are only run for a short period and therefore do not suffer from heat soak on the intake etc.
Given all that information I'd guess that 1.25HP/CI is a more realistic goal for a street driven vehicle, that's about 225 from a 3.0 and should be a real blast, whether the heads need ported to get there or larger than 32mm are required I really don't know. The truth is cam timing usually has a larger influence on power and drivablity that port size and volume, it is possible to undercam a large port for drivability but that doesn't make sense. My best advice would be to maximize the ports you already have for a reasonable power level, cam it correctly and install a good exhaust and intake. Remember the 911 engine is a detuned race engine, not a V8 grocery getter, there are no huge gains to be found. |
One question, the 2.7 RS made 210HP, I don't know if that was net, gross or DIN. What size ports and valves did it run? How about cam timing? I calculate about 1.28HP/CI for the RS or 77.7HP/liter that would be 233 for a 3.0 or 187 for a 2.4, seems to me just copying what the factory did would be easier.
John, just curious if you have done any number crunching on the late SC 34mm intake ports?
Tom |
My experience with poorly flowing ports is that you have to "overcam" to get real power with them as opposed to a more mild cam with great ports, the latter has more usable HP and torque. This is why I suggested maximizing existing ports. I guess it all depends on your version of the word "streetable". Lastly I would also be interested in 3.0 flow numbers as well as 3.0/3.3 turbo flow numbers since I'm considering low compression JE pistons (yes they will make them for me) and either a turbo or supercharger in the future. |
Quite and Emcon;
You'll need to do your own work on the CIS and Turbo models because the situations are completely different in both of them. This should be a new thread for each of them. The CIS (I believe) tends to run a slight vacuum because of the obstruction from the air meter. At peak HP I suspect this gets worse. But I don't own a CIS 911 to test this, nor a CIS anything. it would be interesting to hook up a vacuum meter and track the vacuum versus load and throttle position. It would be awsome to log it with a data logger. At a minimum it would be interesting to do a couple of acceleration runs in 2nd and 3rd gear to see what happens. Anyhow, if the pressure in the intake of the CIS cars is below ambiant, that is a whole 'nother can of worms. Turbos on the other hand run pressurized intakes and the intake size and shape affect the turbo's reaction. In either case I don't have much data and so I don't have much to go on. Given that, you won't get much from me beyond some vague guesses. If you'd like to collect the data on the other hand... |
Another thing I forgot to mention is that theoretical flow requirements can be misleading, the more important flow number would be the entire intake system as well as the entire exhaust. In other words the heads and cam may be capable of making X horsepower but are limited by the rest of the engine, this is why I stress looking at the engine as a system. For example a 40mm carb is limited at some point on a 911 and you must move to a 48mm. What size injection runners did the RS have? |
Whoops I was writing as you were posting. Anyway I was just curious about flow rates of various 911 cylider heads. I've had this wacko idea of using 2 small 4cyl turbos on custom headers run into a sds or megasquirt controlled sheetmetal intake. I'm a pretty good fabricator so this would be a fun project for me but without knowing the flow of the heads I don't know if adding turbos would be worth it as opposed to just buying a turbo engine and selling my 3.0 to offset the cost.
I used to have a chart somewhere that related intake port cfm to HP but I can't find it. I do remember that I selected the porting for my drag engine based on this formula and it was just about dead on. It's been years since I've been in the drag racing loop so I'll have to dig up some old friends and see if they know. |
Circular ports are infinately superior to any rectangular port in terms of airflow for a given cross sectional area. Air flowing is a lot like water flowing. Ever wonder why water flows so much faster out the drain once the swirl forms? The math is horrendous, but can prove the point. Same is true for microwave wave guides. Circular polorized waveguide is much much more effecient than rectangular guide, should be the same for any other fluid in a pulsed or periodic system. Bottom line, you cannot compare chevy rectangular head ports to round Porsche ports, directly.
In any case air flow is air flow, easily measured, on an air flow bench. There is no magic, if you get enough air, then all you have to do is to add fuel in 13:1 proportion, no magic there, and you get the corresponding power. In a fixed size engine, given the displacement, you get such so much air each time the piston goes down, to suck more air you just do it more often, ie higher RPM. The limit is either the head or intake tract, or the basic displacement and RPM. IF the head isn't limiting the flow, then it may be other things, ie the carbs, the intake runners, the air flow meter, whatever, or the RPM. That simple. In the case of the 911 heads ITS NOT THE HEAD. You question the air flow measurements. OK whats the basis? Do you have other head flow measurements, are they with a commercial air flow bench? Do you have more than one? Do you have the math to state that it isn't possible? IF so then I will be challenged to look into my measurements further. |
jluetjen
I don't want to hijack the thread, but in context of your comments on flow rates, valve overlap and duration, I have a question on cam timing. On a 3.0 CIS motor (78 Euro SC), are there really any perceivable differences between the cam timing specifications for the different production years as far as peak HP or torque range goes? I have to install Carerra chain tensioners and will reset the cam timing, so I have an opportunity to experiment. What does your analysis predict, and can you offer any insights? Common knowledge suggests just setting the cam timing midway between the early and later years' advanced/retarded settings, but it would be interesting to see if your calculations show up anything else. If this subject has been beaten to death in other threads, I will apologise and disappear into cyberspace......... Thanks LeRoux |
Porsche played around with moving the cam timing around on these 3.0L engines, moving it and then moving it back. I don't think there's any large, hidden HP in changing the cam timing, but then again, I haven't dynoed all of the range...
-Wayne |
Quiteboom;
I would suspect that you are getting a VE of greater then 1:1, but most likely at your peak torque engine speed, not your peak HP engine speed. If you are thinking about fabricating a Turbo inlit, the parameters are going to be completely different from NA inlets. To be honest I don't know enough to give you an opinion. Snowman, The 911 head flow data that I have is what you published and what BK911 published. Unfortunately they don't match too well as I mentioned although BK did test some of my heads and some of his, and the data was consistent between the two. I gave you my calculations already. But if you don't have anything new to bring up don't bother researching it further, I'm willing to let it drop at this point. |
Rule of thumb for advancing or retarding cam timing:
1 degree advanced moves the powerband 100rpm lower in the rpm range, 1 degree retarded moves it 100rpm higher. Advanced is typical for a street vehicle and many cams for cars other than 911's have 3-4 degrees advance built in. |
John,
THis head flow data shouldn't be a big secret, Hopefully some others who have access to a real flow bench, can pitch in with their info to the benefit of all. A limited time offer. I will flow test and publish the results of anyone who is willing to lend me their head for 2 weeks. It must be done before the end of May 2004 or waiting until Sept of 04 when I can again access the equipmet. Cost, nothing. I will post flow results, along with a photo or two. All I would need is your head and an intake and an exhaust valve. I will test it and return it with data withing a 2 week period. Send me a private e mail if interested. |
I just pulled apart an 2.7 RS spec motor and was surprised to see that the intake ports were a whopping 41.5 mm. If I recall correctly, the exhaust ports were 35mm which was the stock size for the RS. The prior owner absolutely raved about the motor and indicated that the 3.6 he installed didn't have as much torque as the RS (maybe he has a tired old 3.6?) Anyway, the porting job on the intake is beautiful and I want to preserve it for possible replication in future rebuilds by creating a mold. It would be interesting to assess the flow characteristics of these heads. The heads are at German Precision right now getting a full valve job. I'll contact jack to determine if his plate is full yet.
Not yet.
I just received 2 heads today and will be flow testing them first thing after spring break. I can do maybe one more that week (mar 21-26) After that it would be the last week of April before I could do another, none in May thru first of Sept. We will see after that I will send the results to the owner of the heads first, wait for a response and post pictures and results when I get confirmation that the owner has received his results. Not asking for permission, just a courtesy. |
I have received the heads, see photos below. Note the big difference between S and T intake port sizes. Note also this the ONLY difference, ie same valves same port sizes, except at interface.
The Superflow bench that will be used to measure the exact air flow of each head. http://forums.pelicanparts.com/uploa...1079508292.jpg http://forums.pelicanparts.com/uploa...1079508306.jpg http://forums.pelicanparts.com/uploa...1079508323.jpg http://forums.pelicanparts.com/uploa...1079508336.jpg |
| All times are GMT -8. The time now is 03:34 AM. |
