OK fellow Pelcanites...Here's the deal. 78 3.0 rebuild in progress. Need to replace all my head studs. What should I use? Are steel studs OK?
Andrew Gruppe B #055 78 911SC 74 914 2.0 02 C230K Kompressor 73 VW Beetle AutoStick 02 F250 4X4 (Parts Hauler) 03 Kia Sorento (Wife's DD) |
JOT MON ABBR OTH
I used all steel studs on my re-build. Street car, no racing, no track, just daily driver. ARP, Racewear, etc were overkill for my return to stock application.
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Finally, some good news!! Thanks David.
I have just spoken with a Porsche specialist in Oz her about my rebuild. I am putting in 10.5:1 pistons and his recommendation is to go with steel head studs and standard rod bolts. He reccons that ARP and Raceware are over kill for anything other that an out and out race engine.
Would be good to have more feedback on this for both Andrew and myself. Cheers Mark...... |
no sense going ARP on a stocker. that one w/10.5 compression wouldn't hurt to have them. (the rod bolts). cheap ($225) insurance.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 02-24-2004 at 06:05 PM.. |
I am in the same situation on my 78 but was not planning on changing out the upper studs (only the lowers in 78+ were Dilivars). I only have lower ones that are broken. And I purchased OEM steel ones.
Is not replacing the uppers a bad idea? Thanks Jim
78SC Porsche Targa, 71 911T 86 Mazda RX-7 ITS SCCA racer 05 Porsche Cayenne 05 F350 Powerstroke 90 Miata |
just the dilivars is all you need to do.
I have one broken on my 81 sc. Do I understand all of the bottom studs would be a minimum?
Thanks Kevin
Kevin '79 Coupe |
the top ones are already steel, so no need to replace them. always do all the lowers, not just the broken ones.
