whats the best Cam for a 3.5L Mahle Conversion
I am in the middle of converting my 3.2 to a 3.5L using Mahle Pistons and Barrels. I will also be using a Motec M48 Pro to manage the engine as well as throttle boddies.
Whats the hotest Cam grind I can use while retaining street drivability and smooth idle. My intention is for the car to be a fast road car with occassional track day use. I'd like the power to be wide ranging rather than only available at high revs like the early 'S' cars.
Any help very welcome.
Pete
Old 02-09-2005, 08:47 AM
Still Doin Time
asphaltgambler's Avatar
PM John (the camgrinder) for his rec.
Old 02-09-2005, 08:52 AM
PRO Motorsports
Tyson Schmidt's Avatar
The Mod-S cam is awesome. It is the early S cam, but with the lobe centers widened. It really has a nice broad power band, and still has the nice build up of power as the revs rise. It's a terrific cam for bigger motors.
I assume your compression ratio will be somewhere above 9.8/1?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-09-2005, 08:37 PM
jmz jmz is online now
jmz's Avatar
second the MOD S cam. I have them on my 3.0 and they work well.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 02-09-2005, 08:46 PM
thanks guys.
my compression ratio is 10.3:1. Hence the twin spark!
The Mod-S sounds like its worth checking out. Does it give a smooth idle and provide good drivability on the street at llow reves. Also, do you know the dwell, lift and lobe centre information from the mod-s cam. Also, where I can it from? Is it a regrind or billet build from scratch?
Cheers
Pete
Old 02-10-2005, 01:00 AM
jmz's Avatar
Elgin is where I got mine. Re-Grind off the SC cams
Old 02-10-2005, 06:15 AM
PRO Motorsports
Originally posted by Pete_B
thanks guys.
Cheers
Pete
Yes, the idle is smooth, and great driveability. The specs are the same as an early S cam, but something like 110 or 112 degree lobe centers instead of 97 degrees for the early S cam.
I think Web-cam sells them outright. Maybe Elgin can re-grind your cams, but I'm not sure if there is enough meat on stock 3.2 cams to get the lift and duration.
2004 GT3
Old 02-10-2005, 01:32 PM
KobaltBlau's Avatar
send a message to the user "camgrinder" on this board for details. he will be very very helpful.
Andy
Old 02-10-2005, 04:23 PM
Licensed User
Shuie's Avatar
Send Paul Thomas a PM also. I think he is running a GE80 in his twin plugged 3.5 MFI motor. IIRC, this is a pretty aggressive cam.
Old 02-10-2005, 08:32 PM
thanks guys this is really helpful. Will send PM's and let you all know how I get on.
Cheers
Pete
Old 02-11-2005, 02:10 AM
