Question 14- Pin Plastic Gang Box
2 QUESTIONS,
1 Swapping a 2.7 with a 3.0 in 76 911, the 14 pin plastic holder on the wiring harness that is on the car broken into 6 pieces, where can I purchase a replacment.
2 I understand that between the 2 years that the pin placement is different, where can I find a wiring diagram for the 14 pin box for 76 and one for 81?
Peter
Old 02-25-2004, 01:29 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I'm still trying to find the part number for that connector. I've gotten half a dozen 14 pin connectors from the dealer and none of them work. If you get the right one let me know.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-25-2004, 01:42 PM
Somewhere in the Midwest
MotoSook's Avatar
if the connector/housings are the same shape and have the same pin receiver...you can swap the pins and wires...
There is a thread out there with a list of pin#=fucntion for a 78SC....I saved the picture on the home PC, but I bet if you search for it it'll turn up....
Tim you are SOL for that MFI voodoo crap...but you can modify the 14-pin connector for you use...
Old 02-25-2004, 02:16 PM
Tim Walsh's Avatar
Souk,
I've pulled the part #'s from the archives adn they didn't work. I've tried about everything. I know there out there just can't find 'em. It's not an MFI thing since they're on all the post 70 models. I haven't messed with it about a year since my engine's been dead (SOON!!)
edit: but that was back when I had no clue what I was doing so it might be easy to find I was just clueless at the time I attempted it.
Tim
1973 911T
2005 VW GTI
Old 02-25-2004, 02:22 PM
MotoSook's Avatar
So what you are saying is that you know everything now huh? Kids..when are they gonna learn
Heh heh! Try this.
If this is not exactly wha tyou have/need, start testing with a meter. You should be able to contruct what you have using the above and some smart testing. Good luck...
Someone else may have what you need..or know better than I.....
Old 02-25-2004, 06:05 PM
Tim Walsh's Avatar
am I going to have to show you up when I get up there this summer and show you what the "kids" will do?
Tim
1973 911T
2005 VW GTI
Old 02-25-2004, 06:18 PM
LEARNING ONE STEP AT A TIME, Thanks much, should get me in the right direction
Peter
76 3.0 Targa
Old 02-25-2004, 06:21 PM
Souk,
Is the car side or the engine side..................... I guess if it says 78 sc existing chassis must be the harness runniing forward.
Dah
Old 02-25-2004, 06:25 PM
See:
Broken 14 pin connector
Jim
Old 02-25-2004, 06:50 PM
