Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Gapping Aftermarket Rings
I hope to be putting my new JE pistons on my new motor this weekend if everything goes well but I'm a little worried about gapping the rings. How difficult/finicky is this and how did you take some material off the rings to create the right end gap?
84mm JE's in biral cylinders
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-26-2004, 07:05 AM
Senior Member
Doug Zielke's Avatar
Many D-I-Y'ers would just use a small mill file.
But because I do quite a few m/c engines needing rings, I bought a dedicated ring grinder....
It has a little vise with a grinding wheel. You just crank it up. Does a nice job. Made in Sweden by Tebst, found at a local auto parts store.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-26-2004, 08:08 AM
magic930's Avatar
What is the process for measuring a ring gap?
Old 02-26-2004, 06:22 PM
Tim Walsh's Avatar
what you do put the ring in the cylinder that it's meant to go in straighten it with the piston and measure the gap with a feeler guage. take some material off the end, repeat until proper gap is obtained.
At least this is how I interperted it
Tim
1973 911T
2005 VW GTI
Old 02-26-2004, 07:16 PM
