-   -   To Loctie or not to Loctie, that is the dilemma (http://forums.pelicanparts.com/911-engine-rebuilding-forum/151268-loctie-not-loctie-dilemma.html)
garibaldi 03-01-2004 11:09 AM
Allow me some humor here.
When I open a bottle of Red Loctite, the aroma of cherries fills the air. I dab a little bit behind my ears, rub some on my teeth and greet the day. I use it on sandwiches and in mixed drinks. Its great for diarreah, poison ivy and muscle cramps. It works better than viagra if you rub it on the nether regions, I have only gotten one complaint. Many virgins have been known to use a drop or two on the bra clasps and garter connections.
When I build an engine, I also use it liberally on the front and back of the main and rod bearings, on the valve stems and inside the guides, under the valve face where it meets the seat, I prime the oil pump with Red Loctite and drop a dash or two, or three in the gas tank before I fire her up. I just cant figure out why the engines dont turn over.
Ok, time to get get serious, the previous statements where to wake you up and lighten you up.
LOCTITE IS A BANDAID. ENGINEER AT THE SOURCE- THE ROD BOLT. If you think Loctite is going to save your ass if your bolts stretch beyond their limits, your dreaming!
For arguments sake, lets just concentrate on Porsche rod bolts. These bolts are engineered to operate, and operate well within a confined envelope. If they are taken outside that envelope you are in deep water. SOME rod bolts are are stretch to yield, and this puts you at the edge of the envelope and if taken beyond that limit you are merely cylcing the component beyond the edge of its safety margin. Loctite is not going to help you there.
A rod bolt is without a doubt a critical fastener in an engine, and it requires critical torque properties to operate properly. Using Loctite on the threads will not put you within the predictable torque range. Following the engineers instructions and using what the manufacturer recommends to achieve that torque is absolutlely critical. Usually this is a supplied lubricant, or substitued for with straight 30 weight oil (And not a 10-30 or other multi viscocity at that). Which is the old SAE standard. Locitite Is not a lubricant, it is a locking compound, and it does not posses the molecular properties while in its liquid state to be able to gain an accurate torque flow in a fastener, especially one that is going to rely on the specific torque in order for it to operate as designed.
So using it on the threads of your rod bolts is your choice. I sure would never do it.
If a fastener is free from defects, and installed and torqued properly and not operated beyond its intentions, there is no reason for it to ever come loose. The engineering in materials and thread pitch have come so far that it is no longer a black art.
In conclusion, when they fail you find the threaded section of the bolt if it thread into the rod- still in the rod, and the rest on the bolt in the case. And if it is a bolt and nut affair in the same case, then the failed rod bolt will be found in two- with the threaded end of the bolt with the nut still on it.
In closing, THE ONE THING TO USE IS YOUR HEAD
garibaldi 03-01-2004 04:34 PM
garibaldi 03-01-2004 08:04 PM
Here is some rod bolts that failed, notice how the failure happened at the root of the base of the threaded section. These were torque to yield bolts. WITHOUT THE USE OF LOCTITE.
These did not loosen, they failed. When you take an engine way upstairs in the revs, the inertia will go crazy, and this is what you can end up with. The force of the mass goes up by the square of the RPM. A 280,000 psi bolt can get dwarfed in this range.http://forums.pelicanparts.com/uploa...1078200257.jpg
rcwaldo 03-01-2004 09:10 PM
Some great discussion from the other thread about loctite and rod bolts. I agree with the notion NOT to loctite rod bolts, especially since Loctite will alter the torque reading etc.
If one were super paranoid, and insisted on using loctite, there is a loctite that is called 'wicking' loctite. Its basically a super low viscosity loctite (green strength) used to 'wick' into tight areas such as press fit bearing races etc.
Just torque rod bolts as recommended, then apply a small amount of wicking loctite at the end of the nut/rod bolt.
Chris
garibaldi 03-02-2004 09:09 AM
The only proper way to torque a rod bolt in this case is to use the proper lubricant, which is usually a specified weight oil or a lubricant supplied by the bolt manufacturer. These lubes are petroleum based and will give you the proper friction characteristics to achieve proper torque. Loctite does not posses any of these characterictics, and is not advertised to do so. Sure it is a liquid and slippery, but then so is water, so why not use that on the threads? See the logic? You should never torque any fastener dry, and should always use a lubricant is a specific case such as this. Loctite does not cut it at all.
As far as the wicking type of Loctite, in order for a proper Loctite bond to occurr, the surfaces must be clean and free from any dirt or petroleum based product for it to set up. So if the rod bolt were torqued properly using the proper lubricant, then using the wicking type Loctite afterward would be useless because when it wicks into the threads- IF it wicked into the threads (The oil in the threads would create a barrier preventing the Loctite to wick), it would not be able to achieve adhesion due to the contamination from the lubricant already there.
Bottom line is that Loctite should not be used on rod bolts, and if it is used, then the fastener will not be torqued correctly, so you would have a better chance of having a failure of the unit if that was used instead of the proper thread lubricant in the first place.
Wayne 962 03-02-2004 11:39 AM
I disagree. The problem with stretching on the late-model rod bolts is well documented. Unfortunately, your pics of rod bolts failing in the above picture (I have one just like it in the Engine Rebuild Book) may be caused by a number of factors, unrelated to the actual rod bolt itself. It's possible that one rod bolt comes loose, which causes itself or the other one to snap. Simply stating that the rod bolt failure mode is the snapping is a premature conclusion. The rod bolt coming loose is apparently what happened in the photo that is on page 82, Figure 4-12.
For the Engine Rebuild Book, I put in many hours of research on this and other subjects. Some rebuilders I spoke to used Loctite, some didn't. In general on the early cars, it's a non-issue, as rod bolts almost never fail on these engines. On the later cars, I believe that adding the Loctite will give you an added margin of safety. If the bolt stretches and doesn't have Loctite on it, then the nut will immediately fall off. If there is Loctite on it, then it has a more likely chance of staying attached to the bolt, at least so that you can pull over to the side of the road and figure out what that noise coming from your engine is.
I believe that this added margin of safety offers no downside risk, with the potential to save your engine. It is important to note that in the book I recommend several things that the factory didn't originally. These recommendations are based on the collective knowledge of many engine rebuilders, and are often designed to overcome shortcomings in the factory designs that are known to fail.
-Wayne
Wayne 962 03-02-2004 11:58 AM
Re: To Loctie or not to Loctie, that is the dilemma
Yes - all true, but you are forgetting something too. The fastener has to have an ample margin of saftey in the design as well. It would appear that Porsche under-designed this component on the 3.2/3.3/3.6 engines and thus has been plagued with numerous failures. This is why I do not recommend using factory rod bolts under any circumstances in these engines, when performing a rebuild. In addition, the Loctite adds an additional margin of safety, on a proven weak point in the engine.
It's also common for VW rebuilders to use Loctite on the rod bolts.
-Wayne
garibaldi 03-02-2004 01:35 PM
It is obvious that some of the collective knowlege that you obtained to use in your book is wrong.
garibaldi 03-02-2004 02:10 PM
Wayne, everywhere I look on this site, every post you seem to make, and every response I have read from you does little more than plug the book you wrote. I seems obvious that you are more interested in book sales than the TRUTH and bettering of the breed.
I think it would be in very poor taste for me to come out and damage my reputation by telling you where you are wrong and what I know.
garibaldi 03-02-2004 04:30 PM
No disrespect, but in response to your comment on someone hearing a clickety click noise in the motor, and the Loctite giving you some extra time to pull over and save the engine, the guy who had the remnants in the picture I posted uphere heard the noise....... and pulled over, but the I dont think that the Loctite would have helped.
blue72s 03-02-2004 05:12 PM
DVD
Watch the DVD - "Porsche, one for the road" made in 1973. You'll see how the factory worker installed con rods and rod bolts...
OIL OIL and more OIL SmileWavy
rcwaldo 03-02-2004 07:03 PM
I wouldnt call it useless, but yes, I completely agree, for a proper loctite bond, all surfaces must be degreased and with stainless and Ti materials, a loctite primer has to be used.
You would be amazed at the bonding ability of loctite, even with an oily surface involved. An example is we have a few coupler nuts inside a racecar gearbox where antiseize (Copaslip) had to be used to prevent galling and false torques upon assembly. After torqued to 250ft/lbs., we had a problem with this input shaft coupler nut coming loose on several occasions. The fix was to apply a small amount of wicking loctite after assembly, which luckily cured the problem. Removing these nuts were unbelievably tough. Eventually we learned that mixing standard red 272 loctite with Copaslip provided ultimate situation making this particular nut easier to work with.
Excuse me for straying off-topic in regards to rod bolt applications, I didnt mean it..... really:)
garibaldi 03-02-2004 07:28 PM
Is there any specific ratio that you mix the antiseize and loctitie at?
Wayne 962 03-02-2004 07:42 PM
First of all, the book speaks for itself. I do not like to repeat myself when I have already spent 1,500 hours researching and writing a book on the subject. If there is information that is in the book, then I point people to that information.
This is funny. Perhaps you should read some of the 100s of technical articles I've written, or look at some of the other 8000 posts on this BBS before you mouth off like that.
I think that you have already shown rather poor taste already in your replies to my posts on this thread.
In this world, there will always be pundits. The world is not black and white, there are shades of grey to everything, and in this case, there is no definitive right or wrong answer. The book has been based on plenty of good research and it stands on its own. I would guess that you haven't seen it. I don't need to defend it - it speaks for itself.
-Wayne
Wayne 962 03-02-2004 07:52 PM
The absolute proper way to tighten these bolts is not with a torque wrench, but with a stretch gauge, which actually measures the stretch length of the bolts. This is really what matters, not the actual torque reading on a rotated fastener.
Jerry Woods uses one of these stretch gauges to make the point in his engine rebuild class. If you really want to to wild - use one of these gauges and use the Loctite as well. Since the stretch of the bolt is not affected by the application of the Loctite, there should be no changes in the resulting final torque.
One of these days, I will have to dig out a stretch gauge, and measure the total stretch on one rod bolt while using oil as a lubricant, and also on another using just Loctite.
-Wayne
Britwrench 03-02-2004 08:21 PM
I have seen plenty of different makes of engines and can't recollect any sort of locking chemical being used. This includes watching the factory technicians assemble 911 engines.
Regarding the 3.2 rod bolts, the failures usually occur due to abuse (over-revving) causing rod bolt strech, not bolt loosening.
Once the rod bolt tension is lost and therefore also bearing clearance and crush, no chemical in the world is going to stop rod bearing failure, loss of oil pressure, bearing spin and rod bolt breakage. On a high-rev 3.2 you should always use better quality rods.
As with the picture on the post, we lost a 427 cu. in. BBC last year due to oil pressure failure. The bearing then span and subsequentially the rod bolts broke.
garibaldi 03-02-2004 09:15 PM
Wayne you are turning this into a gun fight. I was merely trying to share some information.
Fisrt I will adress the other two guys who posted right after you
Noah; I feel like I am invading Wayne's house. This is his engine building forum after all, I am just a guest. I was raised better than that. I unfortunately cannot point you to a book I wrote, or a website to take this elsewhere. The information that I have is by no means secret and I would be more than happy to share it with you. Wayne should give permission though, since it is going to go against some of the stuff he writes about in his book. This is not slander, its simple ethics, and EXPERIENCE, which I am now questioning from the opposing side. This is a discussion of differences in philosophy.
I will do you one better, and I invite anyone interested to see for yourself. I ENCOURAGE YOU TO DO THIS! Get off your tail and find out for yourself, not just take someones word for it:
Wayne, dig out your stretch gauge and find out the differences with using the various compounds, but dont just use loctite and oil, try STP, try it dry, try it with anti- seize, gather some data. Measure the stretch and torque angle. FInd out how much longer the bolt will stretch in each instance to reach the same torque. Find out if the bolt is loaded with the same tension when it is at the particular torque.
For everyone else, take the time and look up on the web for the ARP website, I am sure they have an email or toll free number, call them up and speak to someone in engineering and ask them what they would recommend using during assembly of their rod bolts. Be sure to throw in the idea that you were going to consider using Loctite, and see what they think. That way you can get another opinion.
I am sitting here right now writing this and staring at the back of a box of ARP fasteners that not only has a chart that clearly shows approximate torques for their various fasteners, with one column for ARP assembly lube, and the other column with a different torque if you are using 30 weight oil- but right next to that it gives more information on how important the proper lubricant is when assembling a fastener. FInd out for yourself.
Britwrench, you are absolutely right. You would be more likely to have a failure if you used the loctite, since in doing so, the rod bolts are not going to be torqued properly to begin with, so its anyone guess if they would loosen up rather than if they were installed properly from the onstart. The onyl time I have heard of a rod bolt loosening up and unscrewing inside an engine on its own is because someone did not properly tighten it. And in these instances the pecker tracks are on the parting faces of the cap, and on the bernelling or transfer of metal on the back of the bearings.
Wayne, I apologize, I was not trying to repsond in bad taste. I am sorry I have some across that way. I do not think that I am acting as a pundit, I am not tormenting you, or stealing your wind. I am just sharing information.
camgrinder 03-02-2004 10:35 PM
That connecting rod in the picture is very black. If the rod bolt did not stretch and/or the housing bore did not go out of round and lose the bearing, then the rod big end should be normal color.
Were those ARP bolts? I can't believe an ARP 280,000 psi bolt could just break like that on thier own.
Randy Webb 03-02-2004 10:50 PM
Exactly. Even if not ARP, the socket design is that of a high strength aerospace bolt, AN or newer spec. UNlikely it would fail without something else going very wrong.
The statement re secret knowledge also suggests a lack thereof. If you have something held in confidence then don't mention it at all. If not, then let's hear it.
Wayne 962 03-03-2004 12:12 AM
Not a problem. I am more than open to counter thoughts and counter-opinions on any topic. My word is not the absolute gospel, and I would hope that it isn't taken that way. In life, there are many "grey areas" where there are no definitive answers.
No man is an island, and it would have been foolish for me to write the book based soley on one person's opinions (mine). That is why I did research the finer elements of the book so much. The ironic thing is that for the many people I spoke with and conferred with about information for this book (Steve W., Bruce Anderson, Jerry Woods, Tom Woodford, Walt Watson) - I found many, many areas where all of these experts disagreed with each other on at least one topic. This was a very difficult situation for me, as I had to weigh all of this conflciting information together, filter it using my background in engineering (BS & MS from MIT) and then come up with a finished product. I personally think that I did a good job, and people (both novices and experts alike) seem to like and appreciate the finished product.
No hard feelings here - I actually welcome open forums (this is one). Just keep it on a friendly level.
-Wayne
john walker's workshop 03-03-2004 08:09 AM
ever take a torch to a piece of steel, heat it and bend it? i'm sure that an ARP rod bolt will respond just the same as a stock bolt in that environment. i'll bet the bolt(s) in the disaster pic failed from excessive temperature after the engine lost oil pressure and was then run until something popped. definitely a situation where you can't blame the fastener. i doubt the bolt broke first, and the engine continued to be run with a thrown rod long enough to blue the rest of the rods as badly as shown.
rick-l 03-03-2004 09:43 AM
Is this true?
If you go to a Miata thread on repairing the crank bolt fiasco ( http://www.miataforum.com/ubb/Archives/Archive-000001/HTML/20000913-5-004321.html ) and go down to a post by SOFTOP he says:
>>>" Disclaimer: I work for Loctite."<<<
>>>" The threadlocker on the bolt is also very important. Torque wrenches work on a theory called torque/tension relationship. Basically this theory determines that by applying a certain amount of twisting force to the fastener, a predictable amount of clamp load will be generated. This is only true if friction can be controlled. The quoted torque specification was valid for a NEW fastener in "as received" condition. This means that it was coated with a substance with lubricity equal to that of 30W oil. Less lubricity than this and the resultant clampload will be too low resulting in loosening. Higher lubricity will lead to more clampload which leads to thread failure and fastener stretch. The Loctite threadlockers mentioned have a lubricity controlling agent which provides lubricity in the correct range. Beware - this is a patented property of Loctite threadlockers and cannot be found in any other brand. It will also lock the bolt and prevent it from loosening." <<<<<<
alan911sc 03-03-2004 11:24 AM
I'm reading these posts with great interest. I would seem once the new fastener is cleaned of the " as received " lubricant and locktite then used, the locktite's lubricity would equal that of the as recieved. Providing the new fastener was spec'd with a 30W oil for torque values. It sure would be nice to see something from Locktite showing these lubricant correlations for their various products.
Marankie 03-03-2004 12:17 PM
Hi guys,
Torque is just a means to get to the desired end result, which is a given clamp load in the rod bolt, within a designed for specific stress (pounds/sq in) in the rod bolt.
Porsche allows this stress to exceed the yield strenght of the material (which is why they dont allow re-use of the rod bolts). The alloy steel of Porche's bolts have to be fairly ductile (good elongation) to do this, which generally means lower (tensile) or ultimate strenght.
ARP etc use steel alloys and heat treats to achieve a higher strenght, (but less ductility) with the material yield strength and tensile strenght fairly close together. In this way when properly tensioned, a higher clamp force can be achieved to offset bolt stretching due to over-reving. (dealt with in previuos correspondence)
From an Engineering perspective these bolts are generally tensioned (or preloaded) to about 80% of the yield strenght of the bolt material.
Torque (irrespective of lubricant) is a poor way to accurately preload or tension the bolt, because the coefficient of friction will vary a great deal even during the torquing. (Think about it. If the coefficient of friction varies only 25%, rod bolt preload will be effected 25%, and result in bolt stresses either way too high or way too low).
The best way to achieve correct bolt preload is to measure the lenght of the bolt (bolt head to end with a micrometer after just snugging down the nut, and then rotating (torquing) the nut (in increments) untill the rod bolt has (elastically) streched the correct increment (about 3 thousands inch as I remember for my last 911 build). For personal experience, the rotation torque needed to rotate the bolt one flat at a time, between each micrometer mearurement, far exceeds any recommended "straight" torque number.
The relationship engineering formula between stress and elongation is very well known and is very linear within the elastic limit of the material (delta L = FL/EA). E is the modulus of elasticity of steel (30 million psi). Another method commonly used for say a blind rod bolt, is "torque -turn", where after an light initial seating torque, the bolt head is rotated a specific number of degrees to achieve the desired for elongation (elastic preload).
Because the bolt thread has a specific number of threads per inch, the desired elongation (say 3 thousandths of an inch) due to the specific rotation (degrees) allows prediction of specific bolt elongation and thus preload stress. or clamping force.
Rod bolts when properly tensioned should be seen as extremely stiff springs. and as long as they are not yielded (stresses past material yield point) will retain their preload. Obiously the higher the preload (ARP etc versus Porsche) the higher the "allowed" revs before rod bolt permanent streching and subsequent problems.
Rod bolts(or nuts) will not back out when preload is maintained.
If streched past yield point, the (clamp) joint will fail, the rod bearing will fail, and short term fatique will break the bolt. Finally the rod will break and scatter pieces out of a new and expensie hole in the case.
Loctite will not help. It will only confuse the ability to achieve correct preload. Loctite is aenarobic,and will start to set up as the joint is being put together (the degree of which sort of depends on the assembler's sequence of assembling rod on the crankshaft and then torquing rod bolts. As such it could resist the efficiency of torque being trabnslated into bolt stretch (preload), which would cause the joint to become loose at lower revs.
I have tried to address this interesting rod bolt contraversy from an unemotional Engineering perspective. Hope it helps.
Martin.
Wayne 962 03-03-2004 12:21 PM
I'm sure that this issue can be debated until the cows come home. I did do a lot of research on the properties of Loctite, etc. when I wrote the book, but I don't have any of that in front of me right now (it's in a large box somewhere in the garage), so I can't speak specifically on the lubricating properties of Loctite prior to its curing.
All guesses aside, what a really counts is the stretch of the rod bolt. I don't have the time right now, but the best way to put this issue to rest would be to:
- get a crank and a rod
- get some factory rod bolts
- clean the heck out of the bolts
- apply the oil to one rod bolt and torque (I haven't seen in the factory manuals where it specs the type of oil? - In my early 911 manual, it just says "oil threads and mating surfaces")
- apply the Loctite to one bolt and torque
- apply nothing to another rod bolth and torque
- Measure all three with a stretch gauge and compare
That would give you the definitive answer...
-Wayne
alan911sc 03-03-2004 12:58 PM
This is becoming as much fun as materials testing lab in college. Let's get a Tinnius/Olsen machine and check the yield strength of the bolts while we're at it. Only kidding, Wayne that sounds like the way to go, a comparison using the various methods.
sammyg2 03-03-2004 01:09 PM
Mr. garibaldi, based on your reputation it is obvious you have knowledge and experience. What you seem not to realize is that you are not alone here my friend. There are many mechanical engineers on this board. I have over two decades of experience in mechanical reliability improvement on industrial rotating equipment.
I appreciate your exchange of information and opinions as long as I can manage to ignore your holier than thou attitude. It isn't appropriate or justified.
Loctite is a band-aid as you said. It has it's uses, in some cases it is a help and others a hindrance. In all cases its use is only beneficial to cover up a design or assembly deficiency.
I personally don't believe it would be much help at all on a rod bolt that is tensioned beyond yield as in an over rev condition.
But, torquing is not an exact science. The torquing factor for lubricants is an average, an estimate, and an educated guess. Saying that torquing with straight weight motor oil is more accurate than when using loctite is just not supportable.
I have done testing on over 15 lubricating products in an attempt to determine an accurate torque factor when using those particular products. The intention was to develop a chart that would compensate torque values for different thread lubricants.
The repeatability was not accurate enough to qualify as statistically accurate.
The products I tested varied from STP to ISO 32 mineral oil (turbo 32), from nickel-eaze to lubriplate anti-seize. I even tested loc-tite 242, 262, and 272.
Most products were mil spec and were used as directed by the manufacturer.
We tested products based on mineral oil, paraffin oil, napthetic oil, copper, zinc, lead, and magnesium on several grades and diameters of fasteners.
The repeatability just wasn't there. The conclusion was that the friction of the contact surfaces in the threads and on the mating faces of the nuts and or washers was unpredictable when an accuracy of over 80% was required. That was on new fasteners, the repeatability worsened on fasteners that were used previously or weathered.
The idea of using a torque factor for each lubricating product was basically scrapped.
We now calculate yield based on the manufacturer's testing and certifications, and then calculate the desired stretch on the fasteners.
The desired stretch is achieved and documented by one of the following techniques:
Measuring overall length before and after torquing with an outside micrometer or similar tool.
Measuring overall length of the fastener before and after torquing with ultrasound. This is very accurate especially on longer studs and bolts but is expensive.
Calculating the number of flats of the nut required to properly stretch the fastener (not as accurate as the other methods but more accurate than a torque wrench).
I consider using a torque wrench to tension a fastener just one step above using a pneumatic impact gun.
For most fasteners it wouldn't present a reliability problem due to the high safety factor designed in.
I the case of the rod bolts in a 3.2 liter engine the safety factor is not as high.
If someone were really concerned with the reliability of the engine I would recommend measuring the actual stretch of the bolt, not the twisting force of the nut.
aseem 03-03-2004 01:10 PM
Originally posted by Marankie
Hi guys,
Which is why in some applications special torque washers (or rather clamp load washers) are uset to achieve the correct clamping load. These washers deform in a specific way when the specified load has been achieved. Needless to say, they too can only be torqed once.
I am no expert in this field, but find this discussion very interesting.
garibaldi 03-03-2004 02:42 PM
If you go back to the first post on this thread, I said that loctie is a bandaid. I also said that the issue was with the rod bolt, and I said that the solution is to engineer at the source- THE ROD BOLT.
All that the subsequent postings by many of you have done is just reconfirm that fact in varying degrees of elaboration.
I said it, I am not apologizing. I am no expert, nor am I better than any one of you in here or out there. Its a shame that my comments were misconstued by some of you as me being arrogant. Many of you seem to liken it to me walking into your party, going up to the host, kicking him in the nuts and then going over and grabbing myself a drink. Sorry that it may not have been as politcally correct as many of you would have preferred.
That isn't the issue here nor the focus. All I did was disagree with the recommendation of using Loctite on a rod bolt in this instance. I never brought up the book, it was repeatedly referenced to, that is why is came up I knew of no book. Look closely, all I began by saying was not to use the Loctite. I made no mention of anyone, nor their work, I didnt even mention anything about myself. Its irrelevant, but alot of you are offended by this, so what would you like me to do? Leave, keep my mouth shut? Take what anyone says witha grain of salt including me, and lighten up, its only a damn rod bolt. It is what it is.
If you are offended by another view, then dont read it. Use what you want to in your engine. And I have no secrets to hide, I am not sure where that one came from. I am more than happy to share the things I know, while it is not much by any stretch of the imagination, but perhaps it could help.
And I appreciate all of you engineers and others that responded and elaborated on what I stated in the beginning in a more condensed verse.
Wayne 962 03-03-2004 02:59 PM
Welcome aboard - your initiation is complete!
Your knowledge and opinions are indeed welcome here.
-Wayne
Fishcop 03-03-2004 03:35 PM
Absolutely what Wayne said....
I once p!ssed in the laundry tub at a party 'cause the toilet was full... The host didn't like me after that either :)
jgparker 03-03-2004 04:55 PM
To summarize...
So, my conclusion is loc-tite will do no harm, and may even be equivalent to 30W oil for lubricating properties (according to loc-tite anyway). In additions, we all believe that the bolt stretch method is far superior to using even the best torque wrench and lubrication available, as far as producing accurate clamping force....
So where do I find the stretch spec for a stock 911 rod bolt? I have never seen this spec is ANY Porsche reference book or in this forum. Racewere has a stretch spec for their bolts, but none for OEM!
Here is a nice picture of a stretch gauge for anyone who does not know what I'm talking about. You torque the nut with the guage on the bolt.
http://forums.pelicanparts.com/uploa...1078361319.jpg
blue72s 03-03-2004 07:58 PM
The other problem about Loctite is that if you apply it on too much, it will escape to the mating surfaces between the nut and the rod thus will act like a thin soft washer after it has cured.
garibaldi 03-03-2004 09:13 PM
Stop. READTHE FIRST POST. Take care of the engineering at the source. THE ROD BOLT.
Wayne 962 03-03-2004 09:33 PM
Agreed. Particularly on the 3.2/3.3/3.6 engines - do not use the factory bolts - use aftermarket ones. (page 62).
-Wayne
Mr Beau 03-04-2004 12:51 PM
Ok, time to through in my two bits...
If you're using a stretch-gauge like the one shown, it doesn't really matter if you use Loctite or not. This is because, as others have mentioned, it's the bolt preload that really matters when it comes to the bolt functioning properly. The load has everything to do with the nut coming loose, and the fatigue life of the jointed assembly.
However, if you are not using a strech gauge, I would argue that you are doing more harm then good. The torque-stretch relationship of fasteners is greatly influenced by friction (both between the bolt/nut and the nut/con-rod surface), and by using a lubricant other than what was envisioned by the Connecting Cod Fastener Design and Release Engineer (someone translate that to German!), you are affecting the bolt preload. Under-loaded and you're at risk of the nut coming loose and/or fatiguing the bolt. Over-loaed and you're just looking at fatigue. Either way, it's best to use what's recommended.
If you happen to use Loctite, I still don't see how it would prevent a more catostrophic failure from happening. Say the nut does start to loosen and the Loctite prevents it from coming all the way off. If you look at the stress the bolt experiences during the up-down cycle if there is no preload (i.e. the case where a nut is coming loose), it is rather enormous and I imagine if would yield in no time.
ischmitz 03-04-2004 02:02 PM
Originally posted by sammyg2
Mr. garibaldi, based on your reputation it is obvious you have knowledge and experience. What you seem not to realize ........I would recommend measuring the actual stretch of the bolt, not the twisting force of the nut.
OK, let's get nasty:
So Sammy, who's your ghostwriter????
Just kiddin. We missed you at Willow Springs this last Wednesday. Is your car back together?
We saw a rod cap peeking through the 2.4 case of Scuffy. My theory is that lots of detonation due to a lean running condition we had all day hammered the hell out of the rod bearings. We could hear some (bearing?) noise when coming into the pits from the second to last run. We thought is was the tranny or a CV joint. During the next session the engine grenaded while Jack was driving the car. Apparently, the detonation hammered the crap out of the rod bolt. Here is a picture of the culprit.
http://forums.pelicanparts.com/uploa...1078437426.jpg
Ingo
1fastredsc 03-04-2004 05:23 PM
UM, that stretch gauge looks like a dial gauge hooked up to a "c" shaped holder. Am i correct in assuming so. Where can you get that holder and as already stated, where does one find the specs on stretch for the rod bolts?
sammyg2 03-05-2004 12:20 PM
Ingo, I'm signing copies in the lobby;)
Car is back together and running at conservative boost levels for now until I have time to tune the CIS for higher levels. Goes like a skinned cat compared to before.
I'm still stuck at work, my next day off will prolly be in April.
Wayne 962 03-05-2004 12:56 PM
Re: To summarize...
That is roughly what I concluded as well for the Engine Book. There are people out there in this world who will argue up and down about the "right and wrong" ways of doing things. In this case, the torque measurement is based on 35+ year engineering and documentation. There are many things in tne Engine Book that I altered or updated from the original factory manuals to incorporate and emphasize progress that has been made since then.
The comment about a torque wrench being one step up from an impact wrench - funny but true. I know from my days working on Satellites at Hughes that torque specs indeed are very subjective. In reality, if a design is engineered properly, then it will have enough built-in margin to compensate for the variations that exist in the tightening process. These variations include material deformations in both the nut and screw, temperature variations, humidity, lubrication, surface prep - the list goes on.
The bottomline is that rebuilders have been using Loctite on the rod bolts for many rebuilds without any problems. Many rebuilders have not been using the Loctite too, and have had many successful rebuilds. In my mind, it's relatively minor issue in the grand scheme of things.
-Wayne
