long board
Guest
Posts: n/a
Torque readings
How do you know if t a torque wrench is calibrated correctly, or not? Especially a new one.
Thanks,
Deane
Old 03-05-2004, 01:11 PM
Author of "101 Projects"
Wayne 962's Avatar
Typically, you have it calibrated by a specialty tool shop. If you have a beam-type wrench that almost never goes out of cal, you could do a rough comparison by measuring one against the other. Theoretically, this should work, although every instruction pamphlet I've ever seen says that this is not an approved method for calibration...
-Wayne
Old 03-06-2004, 12:45 PM
