jluetjen's Avatar
Question Cleaning Engine Parts -- Best way?
Snowman recently returned the heads that I sent to him in "Better then sent" condition. As I sent them they were slightly better then "as removed" condition after cleaning them with degreaser and brushing. I doubt that he got them that clean just using a parts washing sink. If you look at the heads in his pictures on the head flows thread, you'll see that they are now spotlessly gray. Even the iron cylinder that I sent is now beautifully clean. Yes, I'm suffering from cleaning envy.
So Snowman, how did (or do) you get them so nice and clean and shiny gray? The same applies to the valves, especially the exhausts. I soaked my exhausts in Chemtool for a few days and still had a heck of a time getting any of the old carbon off. Wire brushing on a drill didn't do much, the only thing that helped (some) was scraping it off with a gasket scraper.
I'm a big believer in getting engine parts clean before rebuilding them, but what's the best way(s)????
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-30-2004, 11:50 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
John,
I am/did use scotchbright and kimwipes combined with kerosene or acetone and it worked well. My heads and rods came back from the machine shop blasted and my biral cylinders, washed. I ran new JE pistons so those were (mostly) clean.
Sorry I don't know how they cleaned my valves but they looked new.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-30-2004, 12:38 PM
jluetjen's Avatar
FYW, According to Snowman, he did my heads for a couple of hours in a "hot tank" and bead blasted the valves and cylinder, followed by a good washing with detergent.
I assume the "hot tank" had aluminum friendly solvent in it.
John
'69 911E
Old 03-31-2004, 08:19 AM
