3.3 turbo crank question
ive just had my 3.3 turbo crank checked and it spun a bearing. the guy at the shop says that the damaged journal is 18 thou smaller than the good ones. as far as i know the crank has never had a grind. can it be saved? is 18 thou too much to come off a journal?
Andy, UK
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
too much. that's almost 2 undersizes, and the wear will not be exactly centered on the journal, so it will not even clean at 2 undersizes. junk crank.
that's 0.45mm too small. I don't see bearings for 0.50mm undersized for turbo applications. YMMV
edit: looks like JW beat me to the punch.. he knows what he's talking about.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
f--k.
is there any other cranks i can use other than a 3.3 t? anyone know of any good second hand ones about? F--K! F--K! F--K!
Cymru am Byth
I think the 3.3 and the 3.2 crank are the same, but don't quote me on that.
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams |
thanks Julian, can anyone verify this?
same
Cymru am Byth
The gear for the distributor is different, so you would need to check that you have the appropriate one for your application.
there is always the option of having it welded up and reground to standard. crankshaft specialists in memphis tennessee is one place that can do it, but shipping from england would probably nix that idea.
Cymru am Byth
I spun a bearing like you, and opted for the regrind, my damage was minimal. I sent it to Ted Robinson at German Precision in CA, he also rebuilt my heads, did a fantastic job.
I know how much it costs for Porsche parts in the UK, I,m from Wales, I would contact Josh Sadler at Autofarm he will know somebody who maybe able to help you.
cheers blokes, what a pain in the arse.
to top it all off the wifes just come in and told me the daily driver is playing up (again!) it never rains............... Andy, UK
