Couple of questions about cylinder base gaskets
1. What sealant does one use on these?. I know Wayne says Locktite but I have heard Curil T is better. Plus, I do know I struggled to get my cylinders off the case due to Locktite on previous rebuild.
2. How many gaskets is too much? Wayne says no more than two but I have heard (second hand) that other engine builders are using more - sometimes up to 4 - to get the deck height correct. Thanks Tristan |
PRO Motorsports
There shouldn't be a need for more than 2 base gaskets, given the available thicknesses. The Factory spec book states flatly that stacking base gaskets is not recommended, but when building custom engines, it is often unavoidable.
I personally don't like to use Loctite 574 on anything that moves around as much as the cylinders do in the case bores. Loctite will eventually crack, and cause a leak. 've torn down a number of engines that used Loctite on the base gaskets, and they all were seeping due to crumbling, cooked Loctite. I use Hylomar HPF, which never hardens, and is therefore self healing. I use it on case through-bolt o-rings as well, for the same reason.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Somewhere in the Midwest
With the right torque on the heads, the soft base gaskets should seal w/o anything on them.
You think that's not a good idea? I've used valves (1" up to 36" diameter) with stainless to stainless seat contact that can hold over 1400 PSIG! The base gasket only has to deal with case pressure. |
Re: Couple of questions about cylinder base gaskets
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Slumlord
Is your engine a 2.7? If so I believe you are limited to .25 and 0.5 mm shims.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
PBH,
Yes, I think you are correct. I have ordered two sets of .25mm and two of the .50mm. This should get me there. Tristan |
Slumlord
I had to use three total.
No Expert
I seem to remember finding 1mm shims for my 2.7 at EBS and competion engineering. I think one 1mm shim is better than two .5mm shims.
Good luck. JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
I may be faced with tearing down my 2.7 to fix a leak at the base of #1. So back to one of Tristan's questions, why would you stack multiple gaskets? Deck height, compression?
'17 Cayenne |
mostly for proper deck height, but you could massage the compression a bit...
to compensate for material removed when the heads are flycut, and/or the cylinder bases on the case are machined. you need to keep the cam thrust plate centered in it's hole in the chain housing so the o ring will seal.
Cheers, Ingo
Ingo, indeed it is. My story on that charlaton is with my attorney now to make sure it is pure, "best evidence". It will be told on every BB I belong to.
'17 Cayenne |
