911 head flows
The following is the measured head flows of two differen't 911 heads. Both have exactly the same valves, ie 46 mm intakes and 40 mm exhaust. One head has 36mm intake ports, the other 30mm intake ports.
The first head, a 911.104.307 dated 8-69 http://forums.pelicanparts.com/uploa...1080361029.jpg The second head, a 911.104.302 dated 11-72 http://forums.pelicanparts.com/uploa...1080361051.jpg |
The setup to measure the flows is shown below
http://forums.pelicanparts.com/uploa...1080192027.jpg Note the high performance valve springs used for the test, thats the one on the right. http://forums.pelicanparts.com/uploa...1080192080.jpg Note that the heads flow almost exactly the same up to 0.400 inch valve lift. This is very important, especially if you refer to the typical Porsche cam specs, ie they almost never are above 0.4 in lift so why bother??? |
The clay is used to smooth the airflow into the port. It in no way inproves the acutal head flow, it just makes it as though you had a pipe hooked up to it, as in an intake. Its necessary to get the actual performance of JUST the head.
Additional info on the heads: The ports are differen't to a depth of about one inch into the head, after that they are identical, ie valve pockets, measurements at end of valve guide (41.3mm head 1, 41.3mm head 2, same for exhaust. In other words the heads are identical, except for the entrys of the ports and a short distance into the head. All that is needed to open up the smaller head is to match the port to the larger intake gasket, with a straight in cut. Analysis of the performance of these heads on a program called Dyno 2000 will follow. |
http://forums.pelicanparts.com/uploa...1080192530.jpg http://forums.pelicanparts.com/uploa...1080192557.jpg
http://forums.pelicanparts.com/uploa...1080192581.jpg The flow bench, compliments of Saddleback college, Orange Co, CA. |
Jack;
Something seems confusing. The '73TK head (911.104.302.OR dated 11-72) with the 30 mm intake ports flowed 225-227 CFM at .5 inches of lift. The 2.2S head (911.104.307 dated 8-69) with 36 mm intake ports flowed 193-195 CFM at .5 inches of lift. :confused: BTW, here are the nominal port dimensions for the two heads which I measured prior to sending them to you. Inches in from Manifold Face...................307.OR...............302.OR 0.....................30 x 30 mm .........36 x 36 mm .5 inches..........31 x 31 mm .........38 x 38 mm 1 inch..............32 x 32 mm ..........34 x 34 mm 1.5 inch...........35 x 35 mm ..........40 x 40 mm After 1.5 inches the valve guide boss begins to intrude into the port. |
I don't understand it seems tge 2.2S head is less performant :confused:
I've flowed 2.2S and 2.4TK heads without a bellmouth at 28" Hg. My numbers for the S heads are very close to yours. But for the TK head, they are not even close. By the way, I use a superflow too. BK |
Jack: I sent you an email about sending you 2 'E' heads to flow (2.0, 2.4), and have not heard back. Are you still interested in flowing more heads?
BK;
Given that the intake port would normally be attached to the intake manifold, wouldn't it make sense to always use some clay to smooth the entrance of the air. Better yet, for kicks why not hook up a weber carb with a stack and alternatively an MFI manifold and see what the end result is at the cylinder? There's never a situation that I can think of where a 911 engine would be running without something mated to that surface. |
this is good information thank you for sharing it.
Have you ever seen a flowbench or a dyno win a race? When all is said and done, the performance of the engine is what matters. I see so many people put their faith into these testing tools, when what really matters is the way it performs when in its natural environment. I agree, and am jsut putting in two cents. To further expand on your statement, a flow bench in this instance also does not take into consideration piston velocity, intake manifold, exhaust manifold, valve speed, operating temperature, scavenging effects, etc. All it does is test in a controlled and static state. Not to say that they are not useful to some extent, but there is a huge difference between hooking up a shop vac to your head and holding a valve at a particular lift and recording the number, and measuring the flow comparisons at operating RPM, in its installed environment. I have seen head that have given great numbers on a flow bench lose power on the engine and some of the rattiest looking castings make power improvements. So it jsut goes to show you that you should not be fooled into thinking that we have all of this figured out- we dont |
I just had the strangest feeling of Deja Vu -- like if I'd heard those words somewhere before. Since you obviously don't think that there is any value in this thread I guess you don't have to bother reading any further... ;) |
Can we assume that the charts were reversed relative to the captions in Snowman's first post?
Here's Mototune's take on flow benching..
Excerpts: Quote:
I don't know about anyone else, but I'm safely past the "More is better" phase. By the same token, too little won't work either. There are limits such as the speed of sound that limit how fast you can flow your intake charge. Designing in an intake where the charge goes sonic at 1000 RPM (or even 7000 RPM) is not a recipe for success.
There is a "happy medium" and the question is where is that "happy medium" and why is it there rather then at some other number. Now if all of you nay-sayers would get out of the way, we're trying to increase our understanding here! SmileWavy |
What are you getting all bent out of shape for? No one is bashing or "Nay saying" your thread. So relax. Like I said, good info. I will definetely question its valvidity though- all of this testing is done in a controlled environment in a room, on a flow bench and if you are going to argue that all of that doesnt change once that same head is on a motor and operating, then go ahead. I question how valid the numbers that your flow bench will yield once you are in operation? My expereince is that it doesnt matter much. I am not trying to discourage you from experimenting and trying to learn, by all means! But the reality is that at the end of the day, the head is going to be functioning on an engine, with manifolds, and a cam, at operating speed, and with temperautre, with varying throttle positions, and varying loads, with varying injection cycles and methods and so on , and so on, all of which do not get considered, and all of which WILL have an effect on the "flow" numbers in and out of a given head. It was stated earlier in the thread- what was the flow difference when a bead of clay was applied to the perimeter of the port opening? That was a strip of clay, what happens when you put the motor together and run it- how does that effect flow? A bench cannot tell you that. Thats all I am saying- again, its not bad in my opinion, I just put my faith in another number.
Christian;
If you do a search of this BBS for "porting", "harmonics", "cams" and such you'll see many of the subjects which you mentioned examined and discussed. We may not be PhD's, but I think that there is a lot of shared learning going on. On this particular thread, we're looking at head flows. It's agreed that it is not the be-all end-all of HP, but it is one component of the equation -- and one that is definitely not well understood by most of us who are spending the money for improvements. So in my case I'm trying to push the boundries and learn what I can from everyone else so that I can make more informed decisions about my 911's modifications. |
The Wizardry / Alchemy / Artistry of porting, polishing and flowing heads is way beyond my ken, but I can visualize quite a bit of what is presented in this thread. Please keep up with the experiments and presenting the data!
Is it even possible to use the bench to check the changes caused by using MFI components (stax & tb's) vs. equivalents for carbs? That could prove interesting as well. |
The 36mm port flows the most, ie 225 cfm, the smaller one less. I have corrected the data sheet lables to reflect the correct head numbers. THEREFORE IGNORE ALL SWITCHED HEAD REMARKS.
As to the value of flow testing heads, it IS what wins races. The air flow is directly proportional to the power the engine can produce, more airflow, more power. In fact, since we already know that the desired Air fuel ratio will be about 12.5 to one we can calculate the exact ammount of power that can be produced. However there is an OPTIMUM size port, ie you can have to much flow, and to little velocity. You have to know this to make a good flowing head that makes good power. But given a specific design, and going racing usually means that you are going to spin it up as high as possible to get all the power possible, consequently you will need much more flow than a stock head, You also don't care if it runs below 4000 rpm. Not so street friendly, but a race car. for a street car porting usually means matching the gaskets, and maintaining the general size and shape of the ports. And yes you can hook up the entire intake and exhaust system and flow test it. You start, one piece at a time, with the heads. If you can't get the air into the head you don't need to flow any better anywhere else. ONce you have done this you add each component, and test it individually, then togather. How accurate is the power calculation using the head flow, it can be withing 1%, which is pretty darn closel All other things, such as ram tuning can be predicted with similar accuracy. Cam timing is critical but a seperate issue. By the way the similar flows at lower valve lifts make perfact sense. At lower flows, the intake valve is the limiting factor, ie the port is bigger than needed at the low valve lifts. Only when the valve is open far enough for the port itself to become the limiting factor is there a difference in flow. Note that the valve spends most of its time at lower lifts, and very little at high lifts, consequently the heads will perform nearly the same. In fact the head with the smaller port will produce better low end torque, due to higher intake velocities. And for referance I measured the intake flow without the clay, its measured at 0.5" lift and is on the right side of the data sheet. |
Uh Jack -- I think that you did.
at o depth intake 29.6mm vs 35.8mm and exhaust 33.3mm vs 34.9mm at a depth of 18mm into each intake port I got 31.9mm vs 37mm at a depth of 18mm into each exhaust 33.8mm vs 35.1mm If one were to use a drill and went straight into the port it could be opened up to almost identical dimensions to the larger ports. You will have the heads in a few days, please verify part number vs size so the data sheet can be corrected if necessary. |
PS
I have flowed my 912 race car heads, intakes, exhaust, carbs, all connected on a cylinder. I was able to maintain the max flow, 195 cfm at 28 in water with everything connected. I also filled the intake (with the valve closed) with water to the top of the intake stacks. I got 110% the cylinder displacement. The length of the intake stack is exactly correct for peaking at 7800 rpm, as well as the cam. Compression is 12.0:1,I have stepped headers, which hurts peak power a bit, but spreads it out somewhat. The car dynos 140 hp ON THE GROUND at 7800 rpm. Not bad for a 1725cc 4 banger with 80 year old technology. For the technologh, ref :Glen Curtis, of Curtis aircraft, also motor cycles, and so forth. He built an air cooled engine around 1920 that looks just like the VW, Porsche one. He also invented, designed and built an air cooled V8, FROM SCRATCH, put it on a bike and set the world speed record with it, him self, thats right he drove it. If you ever get a chance there is a museum on the south end of Keuka Lake, Hammondsport, NY, the Glen Curtis Museum. Take a very very close look at the air cooled 4 banger he invented and built for an airplane. Makes you wonder who really invented the Vw, Porsche engine. He also received a pilots license, number 1. |
Here is something that we have been working on in regards to valve seat technology. How do you think this will effect the flow?
It is a continous parabolic radius from the valve bowl into the combusiton chamber, this along with a valve seat that is convex to the seat yield a smooth transistion leading past the valve seat, eliminating the multiple angles often used in valve seats, which in turn can create eddies that disrupt the flow. This method we are working on will eliminate these occurrences and cause the flow into the chamber to pass through a true varying venturi whos effect changes in relation to the valve lift. THis is a prototype piece in the picture, so diregard the step at the edge of the seat. Would you be interested in flowing this, if so we can arrange to send a spare head for you to collect some data on. http://forums.pelicanparts.com/uploa...1080327840.jpg |
garibaldi;
Very interesting. I have always heard various things about the incremental improvement to valve flow by using radius instead of the standard 3 angle valve job. The improvement is as you describe. The negatives which I've heard are that while a 5 angle flows better then a 3 angle and a radius flows better then a 5 angle, that it is a case of diminishing returns as well as a significantly shorter life. So if you are building an all-out 3 hour race motor (like a Runoff's motor), get the radiused valve job. If you want your engine to remain strong for a couple of seasons, it's most likely better to go with a good 3 angle or 5 angle valve job. With your professional engine building background have you built many engines with this feature? Do you have any sense as to the life of this feature -- especially with high-pressure valve springs? This may be worth a separate thread rather then making this one thread conveluted then it already is. |
To begin, the seat to valve contact is quite small due to the radius and where the two meet, but as the progression of the valve wears in , we find that the contact margin will reach an acceptable level of about .030 to .040, due to the increased unit load in that concentrated area. Once the contact reaches this state, its further progression seems to greatly diminish as the load is spread out over a larger surface area, and it in turn behaves as any standard valve seat would in terms of load spread. We have also tried moving that process along by a light initial lapping of the vave to the seat and it works fine. This is easily checked and verified without even having to disassemble the motor by either measurin valve lash change, or by more accurately measurin stem depth in the head
This isn't quite the same thing but it is interesting....
Read the last paragraph of that article. It basically says that there are no real answers, and they are trying to make a science from the artform, and it jsut isnt adding up- or in brief, it isnt neceesarily so, or maybe it is.
Good article- sure sounds good, and is good brain candy, but what conclusions does it draw- NONE except that no one has figured it out yet. SO , in repsonse to the quote you posted, there are so many variables that could effect his particular findings that as far as I am concerned, they writer could be full of ####. |
Hopefully Snowman will be able to run one for comparison. Christian; do you have this feature on a 911 head?
Christian,
What I got out of those two article that I posted was that (A) The flow bench doesn't measure the most important stuff (B) What intuitively "looks good" doesn't mean squat I posted the link first article because it bolsters your "flow benches don't win races" view and it was the nicest way I could think of disagreeing with my buddy John. ;) I posted the link to the "full of ####" article because the part I excerpted looked like it might have some relevance to your smooth radius case. -Chris |
Thank you, I wasnt offended by your posts at all.
I am by no means an expert on any of this stuff, and do not have all of the answers, all I can go by is my experience. Like I said, we are experimenting with this type of seat, we are trying various angles and combinations to try and yield the best results. SOme can be more detrimental than others, and that is what we are trying to decifer. The funny thing is that no matter how much "science" so many people try to put on these types of things, there is always a circumstance that comes along at the last minute and seems to defy its logic. All of the technology in mostly every aspect of society- but for this argument dealing with automotive is based on an artform. Way back when before there were computers, dynos and flow benches, guys were making hp based on a seat of the pants and experience approach. I still beleive that when all is said and done- thats what matters, since like I said, you see the technology get defied everyday without any concrete explanation as to why. At some point I think its smart to scrap the computers and data sheets etc, and try your idea, put the motor in the car and run and see what it does. Spending all of that time and energy in a lab is great, but your losing precious driving time. Youve heard the argument that a bumblebee cannot fly right? |
Chris;
Your're lucky that I agree that "Flow benches don't win races", otherwise you'd have to start buying your own lunches ;) . Flow benches DO help a person to understand one facit of how an engine works and potentially (if used correctly) help a person to optomise that facit. But it is just One Facit of the total package. Then there are the other phases of an engine's operation such as was described. Then we get into chassis layout and technology, tires, race craft, driver psychology, gaming theory, financial management, marketing, etc. etc. The trick is to come up with the best combination of all of those things when the green flag drops. To dismiss any of them is to immediately hand a potential advantage to your competitor since you are opting to not compete at that level. Besides, (apologies to Christian, Steve W and any other professional engine builders who are reading this), but I see a lot BS and Urban Myths in the Porsche competition industry hidden behind the "dark magic" mystique. Now, I may not fully understand fluid dynamics and combustion theory, but I DO recognise "Salesmanship" and "Creative Marketing". You know what they say -- it takes one to know one! Now can we get back to talking about flow numbers for 911 heads which is what I think this thread is about. |
I can flow more heads but with a tight time restriction. If i receive the head between April 17th April 23rd I will be able to flow test them. Otherwise next September thru Dec.
To flow a head I need the following: 1. the head 2. a cylinder (can be bad but in one piece) 3. intake valve, can be very used 4. exhaust valve, can be very used 5. valve keepers, 6 valve retainers. IF you want say an intake runner and carb and exhaust header or whatever included I can also do that, but please arrange for return postage if you send any more thant the basic head (items 1 thru 6). Allow two weeks to return items. Jack |
Small changes like this can make significant changes in head flow. These small changes generally make more HP for more flow and less HP for less flow. The changes are usually less than 10% for something like this so they do not tend to affect any of the other engine chacteristics, except for AF ratio. More gas has to be added to compensate for the additional air. Carbs are self compensating. Again nothing else must be the fundamental limit for the flow, otherwise there will be no affect. One last comment. There are several old sayings, one of which is "The power is all in the heads". There is a lot of truth to this statement. Heads seem to be the fundamental limitation on power, everything else can be adjusted accordiingly, but are limited by the heads flow performance. Thats why all the attention to multiple valve heads. For example, Variable cam timing is a great thing, but the limit of POWER is still the head. All the cam timing does is widen the useful power band, it dosen't change the peak power obtainable. Personally I suspect that a lot more useful power could be obtained if some way to place ribblets in the intake runners could be found.. Another promising method of stuffing more air into the cylinder is to convert the airflow into a circular one, eg a tornado like flow. Notice how much faster water goes down the drain when the swirl becomes fully developed? Same thing works for air. Newer chevy heads have a built in swirl for example. Also a device called the "Tornado" has proven to work on a lot of differn't engines. |
Oh no! He's said the "T.." word. There goes this thread down the drain like so much water... :rolleyes:
:D -Chris |
yeah, I have been up at 4 in the morning not being able to sleep and seeing that infomercial too.
A fluid will not go through a pipe any faster if it is spinning. In fact, enough spin could contribute towards the restriction of the flow.
Usually the only time anyone is concerned with swirling air around it is for the purpose of mixing stuff, like air and fuel. |
or a cocktail
| All times are GMT -8. The time now is 03:42 PM. |
