-   -   What torque value for case through bolts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/155442-what-torque-value-case-through-bolts.html)
Ho Hum 74 03-26-2004 05:21 PM
Guys, I cannot find the torque values for the case through bolts OR the perimeter nuts in Wayne's book.
What are the correct values?
Thanks as usual.
Tristan
Eagledriver 03-26-2004 07:04 PM
25 and 18 respectively. From the Haynes manual.
jgparker 03-26-2004 07:22 PM
It's in appendix A on page 200. 25.8 ft lbs and 18.4 ft lbs. I have a copy of this page taped on the wall next to my bench. Is that a copyright violation? Wayne should sell a laminated version of this page.
Make sure your torque wrench is calibrated, and do not over torque the perimeter nuts on a mag case. You'll never forgive yourself if you pull one of the perimeter studs during assembly. This is the fun part...
Good Luck.
JP
911pcars 03-26-2004 10:09 PM
Not saying that Wayne's book is inaccurate, but just to be sure, I would back up any spec info with another source. Typos appear in strange places, if the factory can print them, so can others.
Sherwood
Ho Hum 74 03-27-2004 05:42 AM
Thanks all for the input.
Tristan
