| Registered |  What torque value for case through bolts?
			Guys, I cannot find the torque values for the case through bolts OR the perimeter nuts in Wayne's book.   What are the correct values? Thanks as usual. Tristan | ||
|  03-26-2004, 04:21 PM |
| Registered Join Date: May 2003
			25 and 18 respectively. From the Haynes manual.
				__________________ 72 Carrera RS replica, Spec 911 racer | ||
|  03-26-2004, 06:04 PM |
| No Expert |
			It's in appendix A on page 200.  25.8 ft lbs and 18.4 ft lbs.  I have a copy of this page taped on the wall next to my bench.  Is that a copyright violation?  Wayne should sell a laminated version of this page. Make sure your torque wrench is calibrated, and do not over torque the perimeter nuts on a mag case. You'll never forgive yourself if you pull one of the perimeter studs during assembly. This is the fun part... Good Luck. JP
				__________________ -- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S | ||
|  03-26-2004, 06:22 PM |
| Registered Join Date: Jul 2000 Location: So. Calif.
			Not saying that Wayne's book is inaccurate, but just to be sure, I would back up any spec info with another source. Typos appear in strange places, if the factory can print them, so can others. Sherwood | ||
|  03-26-2004, 09:09 PM |
| Registered |
			Thanks all for the input. Tristan | ||
|  03-27-2004, 04:42 AM |
