adomakin's Avatar
is there TWO stock sc cam profiles?
i was reading the bible (red in colour with a picture of a big engine on the front) a couple of days ago and unless im reading it wrong it looks as if there are two different cam profiles listed for the sc engine. is this true? if so, which profile should i be using for my 3.3 turbo urgrade?
Andy UK
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 04-12-2004, 11:21 PM
Author of "101 Projects"
Wayne 962's Avatar
I'm not sure what exactly you are looking at, but as far as I know, there is only one profile, but two different part numbers. These correspond to the two different types for fastening the cam - the big nut and then the bolt on the end of the cam (early/late).
-Wayne
Old 04-13-2004, 12:17 AM
drag racing the short bus
dd74's Avatar
There are three known cams with three different profiles that work with CIS on the SC engine. They all are touted as "SC performance cams", so maybe this is from where your question derives.
Those cams are:
1) 330 cam from Elgin
2) 964 cam from the 3.6 engine
3) 20/21 cam from Webcam
The 330 cam is the mildest. The 20/21 the most radical.
The Terror of Tiny Town
Old 04-13-2004, 09:30 AM
adomakin's Avatar
cheers fellas
Andy
Old 04-13-2004, 10:30 AM
