-   -   camshaft (http://forums.pelicanparts.com/911-engine-rebuilding-forum/156519-camshaft.html)
thor 04-02-2004 06:28 AM
camshaft
hello ,
could you tell me which kind of camshaft is with this ref : 901 105 110 1R and there is a S stamped on the end .
thanks a lot
Doug Steinel 04-03-2004 10:31 AM
The 1966-68 so-called Solex camshad a right cam with the number:
901.105.110.01
Are you sure about that "1R' part? The list of cam serial numbers in Wayne's book do not have any ending in "1R."
thor 04-05-2004 12:46 AM
yes I 'm sure and there is no information in the wayne 's book...that s why i asked this question ...:(
thor 04-06-2004 01:49 AM
nobody:mad: :( :( :( SmileWavy
Glenn from Denv 04-06-2004 06:12 AM
Sorry, no real help here except to say that the number that you see on the camshaft is the casting number. This is NOT the part number. You have the same issue with the case itself and the heads. There are probably more examples of this but these are the most common.
thor 04-06-2004 06:20 AM
are you sure this is not the part number ???? well the only way to know is to measure the lift ...:(
Glenn from Denv 04-06-2004 07:11 PM
Definitely sure. I was searching for a 964 RSR head and that search made me intimately aware of the Porsche parts catalog.
Sorry to be the bearer of bad news.
camgrinder 04-07-2004 10:36 PM
I have seen that casting number more than a few times. If it has an S stamped on the front it is an early S right bank cam.
thor 04-08-2004 01:21 AM
well It 's stamped "S" and the other one "SE" on the end , then it seems to be S cams ? I will compare with my E cams next week when I will dismount the block.
SmileWavy
davidl 04-09-2004 04:41 AM
Hello there.
SE is S Einspritz..ie injection.
kind regards
thor 04-09-2004 06:48 AM
:) SmileWavy
