Short block complete
Thanks to Christ Streit and Souk for leading the team through the short block assembly.
We were hoping to have the long block done but ran into a snag with the deck height. I guess I didn't realise that the copper cylinder base gaskets come in differing thicknesses. When I tore it down I noticed that there were two gaskets under each cylinder. I ordered two of the standard size. When we measured the deck height of cylinder #1 it was .65 mm. Which was a little too tight! Oh well, order some more parts and start again next weekend. Cheers, Tristanhttp://forums.pelicanparts.com/uploa...1081087876.jpg |
clean block, what did you use?
The case was cleaned by my machine shop. I only cleaned the oil passages and the mating surfaces with Scotchbrite and brake/carb cleaner. Tristan |
Lookin' good.. don't forget your JB weld on the plugs.
Thanks Tim. Just did the JB weld on the case and chain housings.
| All times are GMT -8. The time now is 10:52 PM. |
