Ho Hum 74's Avatar
Short block complete
Thanks to Christ Streit and Souk for leading the team through the short block assembly.
We were hoping to have the long block done but ran into a snag with the deck height. I guess I didn't realise that the copper cylinder base gaskets come in differing thicknesses. When I tore it down I noticed that there were two gaskets under each cylinder. I ordered two of the standard size. When we measured the deck height of cylinder #1 it was .65 mm. Which was a little too tight!
Oh well, order some more parts and start again next weekend.
Cheers,
Tristan
Old 04-04-2004, 07:11 AM
adomakin's Avatar
clean block, what did you use?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 04-05-2004, 09:57 AM
Ho Hum 74's Avatar
The case was cleaned by my machine shop. I only cleaned the oil passages and the mating surfaces with Scotchbrite and brake/carb cleaner.
Tristan
Old 04-05-2004, 10:51 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Lookin' good.. don't forget your JB weld on the plugs.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 04-05-2004, 11:04 AM
Ho Hum 74's Avatar
Thanks Tim. Just did the JB weld on the case and chain housings.
Old 04-05-2004, 01:10 PM
