Autopsy of 2.2S - Tales of the weird
Now this is weird - I rebuilt this motor ~5 years ago and didn't notice.
The right (4,5,6) side case half is a 3R case, and the left (1,2,3) side case half is a 2R case. Aren't they supposed to be the same? If I remember correctly, the 3R would be correct for a 2.2S from 1970, and a 2R case would be from an earlier 2 liter motor. And I have never heard of a mix & match with case halves being the proper way to go about building a motor. Sheese!
Kevin 1972 T Targa |
there are a pair of numbers on the top of the case by one of the perimeter bolts.. are they the same? I belive they're labeled much like rod bolts. I've seen 1R/2R(a 69 and a 70) cases, 3R/3R cases (71), 3R/4R cases (a 72), 4R/5R cases (another 72) and 7R/7R cases (73-77). The casting # on the bottom doesn't mean much.. there's a few things you can infer but not much.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer Last edited by Tim Walsh; 04-05-2004 at 06:39 PM.. |
GAFB
Re: Autopsy of 2.2S - Tales of the weird
In fact - I've seen far more mag engines with mismatched casting revisions, than I have seen matched ones. I can't honestly think of a matched set off the top of my head.
Several BMWs |
