3.4 Conversion
I have just rebuilt my engine from 3.2 to 3.4 using Ruf pistons/cylinders and sports camshafts. I am also using a Steve Wong chip. I have just finished running the car for 1,500 km and have changed the oil. A couple of things I have noticed since the conversion :-
1. The engine is running hotter than before (except when cruising along the highway). Very often, I find the temp needle at horizontal or slightly higher.
2. Sometimes, although not often, when I start the engine in the mornings, there is a puff of white/bluish smoke that comes out of the exhaust.
3. Now when I am accelerating in a particular gear (especially noticeable in 2nd or 3rd gear) and I take my foot of the accelerator, there is a slight farting sound coming from the exhaust. Not quite a backfire but a "put-put-put" sound. The sound disappears when I lay on the gas.
Can someone tell me if there is anything wrong and whether I can do anything to eliminate the symptoms described above ?
Thanks.
Old 04-05-2004, 08:23 PM
Re: 3.4 Conversion
I think #3 is a backfire, but nothing to worry about. It's caused by the increased valve overlap of your sport cams.
Old 04-25-2004, 02:48 PM
juan ruiz's Avatar
1) You could install a targa switch to turn on/off the fan when it gets to the "Hot" zone.
2) I dont think is anything to worry must do.
3) Get a "Properly tailored chip" and your problems will be solved.
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 04-25-2004, 03:29 PM
