Jeff Alton's Avatar
An SC that I had a while ago had them installed at some point. They saved the motor when a tensioner collapsed. Promptly installed Carrera tensioners!
Jeff
www.turn3autosport.com
Old 11-27-2004, 10:31 PM
Jubbie's Avatar
With the info given so far, I probably could figure it out. In sizing the stop, how do you figure out the max travel to avoid skipping teeth if the tensioner fails?
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 11-28-2004, 08:30 PM
Now in 993 land ...
aigel's Avatar
Originally posted by Jubbie
George or Wayne,
Did you ever get around to document this mod to the Carrera tensioners. I would be interested since I am there now on the rebuild.
Jubbie:
I finally got to it, after having written about it in a longer article in the local newsletter last summer. You can find it here:
Shops that don't recommend Carrera Tensioner Update?
I hope this helps.
Cheers, George
81 SC (sold)
Old 01-06-2005, 03:03 AM
Slumlord
Porsche_monkey's Avatar
Thank-you. I think it should be posted as a tech article.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-06-2005, 06:48 AM
I'm slapping the defib on this thread and bringing it back to life instead of starting yet another tensioner thread.
Is it possible to do an internal mod, like the Jerry woods oil fed tensioner mod, on the earlier tensioners? My '71T tensioners have given no trouble for 90,000 miles, but since I am in there I wouldn't mind adding some insurance when I rebuild them. I know about the external collar mod, just wondering if there is something that is as failure proof as the Woods mod.
Old 11-07-2016, 11:05 AM
I'd say if the earlier tensioners have a piston and a space where the internal stopper plug/slug can go then I don't see why not. As George mentions there are some measurements that need to be done first, and good point about the pin not working later. I put the GW stopper slugs in when I did the top end. The stock I used was a bronze bushing material from OSH I think, fit perfectly in OD, just cut to length. I don't remember how much "slack" I left - but I suppose it is wise to leave some to accommodate any number of hot/cold expansion scenarios.
Sold: 1989 3.2 coupe, 112k miles
Old 11-15-2016, 12:21 PM
Under the radar
Trackrash's Avatar
The collars work fine, as long as you don't ignore a collapsed tensioner. Those are safety collars, not a permanent fix.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-15-2016, 09:56 PM
I've seen those collar tensioners come loose. If you use the 930 tensioners and pre bleed them with 60W oil, you have as good as you are going to get.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-17-2016, 02:37 PM
Thanks hcoles, I will take one apart and see if there is space in there for a spacer.
Thanks also Trackrash and RSTarga; may end up with the collars or the 930 tensioners.
Old 11-17-2016, 04:56 PM
