-   -   Crank measurements? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/158262-crank-measurements.html)
YTNUKLR 04-13-2004 10:18 AM
Crank measurements?
Hi, are the values for crank measurements listed in the table in Wayne's book the values that "std/std" fits into? Ie., is "the wear limit," 56.960mm, the absolute wear limit before it is junk, or the smallest std std measurement? Thanks
Rot 911 04-14-2004 07:23 AM
It is the smallest standard measurement you can go before you have to regrind the journals and go with undersized bearings.
Wayne 962 04-14-2004 10:58 AM
Right. Anyything more would lead to too wide clearances...
-Wayne
