up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Crank measurements?
Hi, are the values for crank measurements listed in the table in Wayne's book the values that "std/std" fits into? Ie., is "the wear limit," 56.960mm, the absolute wear limit before it is junk, or the smallest std std measurement? Thanks
Scott Kinder
kindersport @ gmail.com
Old 04-13-2004, 10:18 AM
Friend of Warren
It is the smallest standard measurement you can go before you have to regrind the journals and go with undersized bearings.
Kurt V
Old 04-14-2004, 07:23 AM
