Now in 993 land ...
piston to valve clearance, why static???
I am reading the rebuild book and am at the piston to valve clearance check section.
Why do you have to do this static? Why don't you just set the 2mm / 1.5mm clearance on the respective valves and turn the engine over very carefully. If there is no obstruction, you are clear. Especially if you expect no clearance problems since you had no machining etc. but just want a sanity check, I feel that the static method in the book may be overkill / a waste of time? TIA, George |
But I was thinking that in the case of a non-modified motor you could just set the crank to TDC for overlapping valves and take measurements at increments of 5 and 10 degrees before and after. You should be clear. Tristan Last edited by Ho Hum 74; 04-14-2004 at 12:30 PM.. |
I did this on my motor.. sort of. If you set it to the full 2mm and DON"T clear by a fair amount what's going to happen to your valves? I set my lash to 0 then went one half more turns in (0.5mm) and turned the motor over SLOWLY. then @ 1.0 and then at 1.5 then at 2.0.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
GAFB
Re: piston to valve clearance, why static???
We also used Bruce's method exclusively when timing Tim's engine.
Several BMWs Last edited by dtw; 04-14-2004 at 12:49 PM.. |
Now in 993 land ...
Tristan:
If you push in the valves with the set screw to 2.0mm / 1.5mm respectively, you will see if there is a clearance problem when you turn the engine. You basically know that there is more than 2mm/1.5mm clearance at all times, once the valves are set at zero / 0.1mm lash. Dave: Let's see if Wayne chimes in. Of course Wayne knows the 'dynamic' method. I guess he purposely recommends the static procedure since you really don't want to hit the valves, even turningthe enigne by hand. Depending on the shape of the piston, the valves get hit at a rather steep angle and may take harm. Again, if you are 99% sure that you have good clearance, (e.g. you are assembling all your old non machined components) and if you are very careful turning, the dynamic method should be fine as a sanity check. One may also combine both methods. One other method you can do, if you have to dry-assemble and then dissassemble things anyway, is putty, like the pushrod V8 crowd uses it. Just put the putty on top of the piston, time cams, set valves to spec. turn engine over a few times. Disassemble and measure minimum thickness of the putty. That method will give good info on where to machine, if you need it. George |
GAFB
I had some friends who built a pretty insane race motor - they couldn't get good readings with "play-do" (brings back memories). Apparently it would stick to the head and piston and sorta tear apart. They ended up blowing the lead out of some solder and using that. I remember reading something about some special putty you can use just for that, which won't tear or deform. I agree, there's plenty of good and resourceful ways to skin the clearancing cat.
Several BMWs |
At TDC (where you adjust the valves), instead of using a feeler gauge, you use a dial gauge to dial in 2mm (or 1.5mm depending on the valve). Then you turn the engine over. The theory being that at it's worst case there should still be enough clearance to turn the engine. Sounds pretty good, I'll give it a try. Tristan |
GAFB
On my high-compression motor, I did hit resistance at a certain measurement. Be sure to turn the motor over super-duper slowly and carefully when you are coming on and going off cam.
Several BMWs |
At the very end of Wayne's description of this procedure he basically says you can do the dynamic method as a shortcut.
Ho Hum. You don't need a dial indicator. Read Wayne's description. The thread pitich of the screws is 1.mm. Turn the screw 720 degrees and you've dropped it down 2mm. Edit: (posted at the same time as DTW)
'76 911 Carrera 3.0 |
Now in 993 land ...
![]() George |
Author of "101 Projects"
Yes, for CIS/Motronic engines with plenty of clearance, then the shortcut should work fine with no problems. On race engines, or early carb/MFI engines, you should proceed very carefully. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
