how do i increase my comp?
is there a recognised amount to remove from the heads of a 3.3 turbo to achieve a 7.5-1 comperssion? Im assuming that this is the most straight forward (and cheapest) way of increasing compression?
Andy UK
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Author of "101 Projects"
I'm more of a fan of "stretching" the rods rather than flycutting the heads...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Cymru am Byth
According to Bruce Anderson you mill off 1mm (0.039''), will give you 7.5:1.
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams |
Irrationally exuberant
Either way (head or rods) you'll reducing your deck height so you have to be aware of the issues with that. At least if you stretch the rods you don't have to worry about taking up the extra chain slack and machining the chain boxes to make everything line up.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I asked a while back about stretching rods to increase compression. Regardless, you're changing deck height.
Another alternative is to have material machined off your cylinder bases. That way you don't mess with your heads. Rod stretching is, of course, the lowest long-term impact on your engine and totally reversible.
'76 911 Carrera 3.0 |
hmmm.
is stretching the rods a pretty straight forward trick?
is there any calculated specs for rod stretching to achieve a 7.5-1 comp?
1. install higher C/R pistons (if you are making hot ngine you are likely to use aftermakret pistons and they can make everything you like).
2. Install longer rods (same thing) 3. Flycut the heads (and deal with 4mm of added chain length). Or if you want to play with big dogs, dual-plug the heads and use original 7:1 C/R to boost more! ;-) 1.4 bar is handy...
Thank you for your time, |
Sorry about a dumb question - I understand machinging the chain housing, but how to deal with the slack in the chain? Take out a link from it???
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
yeah, whats the deal with the chain?
FYI - for those who are confused, I've got a neat pic in the Engine Rebuild Book that shows what is meant by "stretching the rod."
-Wayne
Wayne, what are your thoughts on stretching the rod vs. head fly cutting vs cylinder base machining?
streching the rods has always left me saying "huh?"
I understand the concept...moving the piston closer to the head. but in the end don't we have a minimum deck height? if we shrink the deck height too much don't we have to shim the cylinder to get in spec? what am I missing?
big AL '77 911 |
i supose ultimately contact is made with piston and valve but there is SOME margin for stretching the rod or skimming the head.
Ive been looking at the pic of the stretched rod in waynes book, it looks as if the bush is quite a lot bigger than the bush in my 3.2 rods. also, what are those bushes made of? my machine man reckons that they may be a combination of two metals but in the pic the bush looks like its all brass or something. anyone?
