adomakin's Avatar
Can I use 3.6 turbo pistons and cylinders on my 3.3 turbo
can i increase the cubic capacity of my 3.3 turbo to 3.6 by using pistons and barrels from a 3.6? i understand that ill have to use a low comp piston but, assuming the 3.6 barrels fit, would i have to run the same compression as the 3.3 turbo? is it as striaght forward as that or would i need 3.6 heads etc?
Andy
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 05-07-2004, 01:21 PM
vichang4's Avatar
I always thought the 3.3 case needed to be modified to fit the 3.6 P & C.
-Vic
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 05-07-2004, 09:27 PM
adomakin's Avatar
is that right? hmmmmm......
Andy
Old 05-08-2004, 01:08 AM
Forced Induction Junkie
WERK I's Avatar
You have to include the 3.6 crank too. The 3.6 turbo is a bored and stroked 3.3. To fit the 3.6 crank, some of the case has to be grinded slightly to clear the throws.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-08-2004, 01:49 PM
adomakin's Avatar
thanks blokes, 3.3 it is then!
Andy
Old 05-08-2004, 02:47 PM
Porschephd's Avatar
You could use 100mm and be at a 3.5 setup. I will not bore a 3.3 case for 100s. The spigots become to thin and will cause issues down the road and certainly will leak. You can go the old way and use liners like Andial did. The most I will open those up to are a 98mm which require no machining to the case. That and a half of point bump in CR and you are set for a nice running car. Don't forget the twin plug for that added heat, I mean HP
Stephen
94 3.6Turbo 6-speed AWD
Old 05-08-2004, 09:17 PM
adomakin's Avatar
cheers steve, you are a very helpfull man!
Andy
Old 05-09-2004, 12:12 PM
