my engine idea, finalized, pretty much...
ok after months of research and debate i have finalized the ideas for my engine rebuild which will occur this summer. firstly the engine in question is a 1978 3.0 SC engine with only an MSD 6AL box and blaster coil and also jacobs plug wires.
my plans are as follows: replace pistons with high compression JE pistons, ratio of 11:1 replace CIS system with modified 009 or 010 MFI pump port and polish heads as well as twin plug S cams my only question is this: should I A, send my dizzy to Andial and have them convert it to a twin plug dizzy or B replace the dizzy with the Electramotive sensor and use two stand alone Electramotive coil packs? as far as future engine growth I think the Electramotive system is better but the 917/935 dizzy looks oh so good. what do you guys think is better?? |
