geof33's Avatar
diagnosis ideas?
3.0 CIS went "poof" from a 5000rpm to 3000rpm drop, smoke, oil in exhuast, oil in the air intake. Dropped one cylinder. Not sure which, PO told me this.
Removed sump, plugs. No obvious signs od fouling, and no metal at all in the motor.
Any ideas? Not a great shot, but here are the plugs:
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-17-2004, 01:52 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
that's not a very good pic but are any of the oily, or have any mechanical damage?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-17-2004, 01:55 PM
geof33's Avatar
There isn't any oil... that's the weird thing. They are fairly carboned up... but no oil. I'll take some better shots. And no, there really isn't any outward sign of failure or anything. they looked pretty darn good overall.
I'll shoot a better pic tonight.
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-17-2004, 04:43 PM
geof33's Avatar
Wayne,
I've already ordered the book. The motor was coming out for a total rebuild anyway, bumped to a 3.2 or 3.3 "S" cams and Carbs... I'm just trying to figure it out before hand!!
Thanks.
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-17-2004, 09:15 PM
geof33's Avatar
Wayne,
Great article BTW... Lot's of good info. The biggest problem is the engine is not currently "hooked up" so I can't crank it with the starter. After reading the article it sounds like it is valve related, maybe a piece of carbon stuck... I'll be finding out for sure in the next couple of weeks as the teardown begins!
Thanks again...
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-18-2004, 12:03 AM
350HP930's Avatar
The plugs could have just fouled up from oil consumption, whether it be from bad valve guides, rings or a little of both.
Old 05-20-2004, 07:20 PM
Author of "101 Projects"
Wayne 962's Avatar
Thanks again...
Right - very important. As much as I like to sell engine rebuild parts, there's no need to rebuild an engine that doesn't need it (the Ferrari disease!). Make sure that you have determined that you really need to rebuild prior to tearing it down.
I didn't think so at the time, but this article has become the number one useful article on this (and the BMW) site. I'm actually including it as a project in the new BMW book.
Everyone who thinks their engine is dead should read it first...
-Wayne
Old 05-20-2004, 08:36 PM
Air Medal or two
afterburn 549's Avatar
Start with a leak dwn teast.......then you will know if its just ez or mech.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-22-2004, 07:16 PM
