diagnosis ideas?
3.0 CIS went "poof" from a 5000rpm to 3000rpm drop, smoke, oil in exhuast, oil in the air intake. Dropped one cylinder. Not sure which, PO told me this.
Removed sump, plugs. No obvious signs od fouling, and no metal at all in the motor. Any ideas? Not a great shot, but here are the plugs:
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
that's not a very good pic but are any of the oily, or have any mechanical damage?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
There isn't any oil... that's the weird thing. They are fairly carboned up... but no oil. I'll take some better shots. And no, there really isn't any outward sign of failure or anything. they looked pretty darn good overall.
I'll shoot a better pic tonight.
Author of "101 Projects"
This is a good read for your problems:
http://www.pelicanparts.com/techarticles/mult_Engine_Rebuild/mult_engine_rebuild-1.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
I've already ordered the book. The motor was coming out for a total rebuild anyway, bumped to a 3.2 or 3.3 "S" cams and Carbs... I'm just trying to figure it out before hand!! Thanks.
Check out the tech article - it will show you how to diagnose the problem...
-Wayne
Wayne,
Great article BTW... Lot's of good info. The biggest problem is the engine is not currently "hooked up" so I can't crank it with the starter. After reading the article it sounds like it is valve related, maybe a piece of carbon stuck... I'll be finding out for sure in the next couple of weeks as the teardown begins! Thanks again...
The plugs could have just fouled up from oil consumption, whether it be from bad valve guides, rings or a little of both.
I didn't think so at the time, but this article has become the number one useful article on this (and the BMW) site. I'm actually including it as a project in the new BMW book. Everyone who thinks their engine is dead should read it first... -Wayne
Air Medal or two
Start with a leak dwn teast.......then you will know if its just ez or mech.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
How were you planning on getting to a 3.3? Carrera crank + Turbo cylinders + JE pistons?
-Wayne
