davidl's Avatar
Hottening T cams
Hello all.
I'm aware I havea pile of early T cams which i should do something with.
I know Elgin's do an E profile on them without welding.
What is the hottest we can go without adding material please?
Old 05-03-2004, 02:34 PM
camgrinder's Avatar
The 911 E grind is all I will put on a T cam without hardface welding.
John Dougherty
Dougherty Racing Cams
Old 05-04-2004, 09:39 PM
davidl's Avatar
Thanks very much, John.
And the hottest for an original E is the improved S grind, yes?
I hear good about that grind.. but will it give the same or better ultimate power as the original s ?
Also, what is the most powerful you will put onto the original S these days please?
Great to have such experts round here..saves many hours!
Old 05-05-2004, 12:26 AM
camgrinder's Avatar
The "E" grind works well in the "T" car with std T pistons. In fact there is a set on Ebay right now....
My favorite upgrade for the "E" lately is the Solex grind done on E lobe centers (102) which fit the E cores nicely.
Some cams will swap out using stock pistons. Some will not!
If your not sure ask.
The Mod-S grind we do is a good upgrade on the original "S" cams. I try to sell hardfacing when someone sends an original
"S" in for regrinding. We can weld and grind a set of "T" cores and save the "S" cams.
I just hate to grind down a good set of S cams.
John Dougherty
Old 05-05-2004, 04:24 PM
davidl's Avatar
Thanks again, John and Wayne.
This is all about stuff I have on the shelf which I'm trying to recycle as econoimically as possible..
And I would not dream of grinding good S, or for that matter E or solex cams!
I do have quite a few of these which are slightly damaged.. not enough to need welding, but needing a resurface.
Is the improved S grind possible on the E core?
And I assume the Carrera 906 is the hottest we can put onto the S cores without a weld..?
Sure I know 'bout the piston requirements.. tho' I have done it , just once, I would say that the T piston needs careful timing deckheighting etc if the E cam is to be used..interesting to learn someone else has actual;ly tried it too!
Thanks again..
Old 05-06-2004, 10:11 AM
camgrinder's Avatar
Your welcome David.
The 906 grind will not fit the S camshafts.
way too small on the base circle.
John Dougherty
Old 05-06-2004, 04:08 PM
davidl's Avatar
Thanks, again.
So really a worn S can only be reground as an S, and the E-into- improved S is possible?
Thanks.
david
Old 05-06-2004, 04:14 PM
camgrinder's Avatar
the improved S grind should only be ground on an original S cam core. It removes about .030" of material from the lobe. any more than that I do not like.
The E camshaft would lose about .045" of material. A little too much.
The solex grind on 102 l/c is the best on E cams.
John Dougherty
Old 05-06-2004, 04:17 PM
