-   -   Does rebuild require new distributor? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/162169-does-rebuild-require-new-distributor.html)
mygatts57 05-08-2004 08:28 PM
I'm planning on converting my 71 2.2T engine to to a 2.4E+ as recomended in Wayne's book for favorite upgrade from 2.2 to 2.4.
I read somewhere that I will have to "recurve" my distributor, or replace with one from an E.
I need guidance. Thanks
Fishcop 05-09-2004 03:35 AM
If you have the Bosch (rather than Marelli) distributor, then it is simple and cheaper to have it "graphed" or "re-curved" to suit the qualities of the new engine rather than buying a new one. Another advantage is they take into account modern fuel (as opposed to the 70's) and the different octanes and set the distributor up accordingly.
As I'm in Australia, I'll let someone else chime in on a recommended place for you over there.
Wayne 962 05-09-2004 03:05 PM
Steve Weiner (board member) does these: www.rennsportsystems.com
-Wayne
