-   -   2.7 upgrade..... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/162410-2-7-upgrade.html)
911schary 05-10-2004 03:27 PM
2.7 upgrade.....
I posted earlier, and it's somewhat clear that under the constraint of 2.7 litres and cis that 210 horsepower is a high goal.. One article I read dealt with a 3.0 cis carrera with a 964 cam reaching close to that goal. Provided I make the jump to higher displacement, what is the best piston,cylinder, cam, compression ratio combo with "reliability" and "driveability" in mind. I really am interested in keeping the CIS, and would be happy with 200-210 horsepower. thank you
Wayne 962 05-10-2004 04:49 PM
CIS really limits your performance ability. It's not a performance system. Noah's JE and 964 combo is about the best you can do with a 3.0L or 2.7 engine and still keep the CIS system.
-Wayne
dd74 05-10-2004 09:09 PM
What's this infatuation with 210 hp? 150 or 160 is powerful enough IMHO. You can get 175 if you build an S motor out of your 2.7 with the CIS.
Otherwise, it looks as if a 3.0 is in your future, and even with that, 200-215 is about the highest I've seen with CIS atop those engines.
And even so, 215 with CIS is accomplished more or less with a hybrid motor, where one mates the bottom end of a newer SC engine (9.3 compression) with the top end of an early SC engine (larger intake runners), 20/21 cams, headers and a loud exhaust.
Fishcop 05-11-2004 01:15 AM
Hmmm, why settle for 5" when a little surgery can give you 7" ;)
